  New Posts New Posts RSS Feed - pcm trans problem
pcm trans problem
ganderson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ganderson Quote  Post ReplyReply Direct Link To This Post Topic: pcm trans problem
    Posted: July-30-2013 at 8:31pm
I have a 1998 ski nat. Snob. I've ntoiced that the last two ski trips it takes about 5-8 seconds for the boat to get into gear. Reverse goes in with no delay. I did a service on it at the beginning of the season also.
I noticed that there is a slight leak on the nut and bolt where the actual shifter is and that the fluid smells burned, but the fluid level is good. Any suggestions?????
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 8:48pm
Have you changed the fluid? Use Dex III or equivalent.
