weight of 88 2001 model |
tonydjd
Groupie Joined: December-29-2005 Location: United States Status: Offline Points: 80 |
Posted: March-01-2006 at 7:43pm |
I was was wondering what the weight of the boat is building boathouse lift did not know if the 2800lb lift is enough or block and tackle to make 5600lb what do you think
Dank
Senior Member Joined: April-05-2005 Location: Austin, TX Status: Offline Points: 296 |
From the 88 Brochure the SN has a dry weight of 2300 lbs.
"I don't know what the world may need, but a V8 engine's a good start for me"
tonydjd
Thank you I wasn't sure how accurate that was. Thought someone actually might of weighed the boat.
tabogott
Newbie Joined: September-16-2005 Location: United States Status: Offline Points: 2 |
I know my manual said 2300 but that is dry dry dry weight and when I did the truck scale drill first with boat/trailer and then with just the trailer; my 88 2001 ended up at basically 2500 as I recall. Tom Bogott
T.A.Bogott
