  New Posts New Posts RSS Feed - 87 SN Transom leak
87 SN Transom leak
ChowHound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChowHound Quote  Post ReplyReply Direct Link To This Post Topic: 87 SN Transom leak
    Posted: August-21-2013 at 9:39pm
Hi everyone,
I'm noticing a trickle leak coming down from behind the tank, on top of the secondary stringer on the driver side.
The only things I see in that area (besides the exhaust port) are the speedo pickup and platform bolts. As the platform bolts are lags, I'm doubting they come all the way thru the transom...correct?
This is my first 2001 type hull. Are there any common suspects for this type of leak?
-Chow
Bones71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bones71 Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2013 at 11:41pm
Chow, I'm not exactly sure how far the lags go in but when I pulled my swim platform off this spring I went to put it back on a resealed all screws and bolts with 3M 5200 marine sealant. You might want to start there. The lags definitely pull into the transome wood. Tony.
That money talks, I'll not deny, I heard it once: It said 'Goodbye'
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2013 at 8:34am
My guess is the speedo tube or expansion chamber is leaking. Disable the pitot on that side & see if the leak stops to verify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChowHound Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2013 at 11:37am
Thanks Guys!
When resealing the lags, are you filling the holes in the transom with the 5200, then inserting the lags. Or, just externally bedding each of the mounting brackets.
I'm hesitant to fill the holes with 5200 as I may need to remove the bolts again some day.
I'll also play with speedo pickups/line etc.
SNobsessed - 'expansion chamber'? - There's an expansion chamber in the speedo line? - no idea what you're refereing to.
-Chow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2013 at 12:10pm
It looks like a 12" piece of brass pipe with 1/8 hose barbs on each end, on your model it's mounted on the inside of the transom. If one of your speedo's don't work it could be the problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2013 at 2:23pm
4200 or sikaflex would be better than 5200.
If thats whats leaking pull the platform, then the braces. Fill holes with 4200 then put a small bead around all the holes(like a gasket) then reinstall the brackets.
dwouncmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2013 at 4:09pm
I found cheap 4200 recently...posted a couple of days ago
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChowHound Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2013 at 8:47pm
Thanks guys!
Both speedo's work so I'm assuming it's the mounting bolts.
Will get 4200.
appreciated - Chow
