  New Posts New Posts RSS Feed - Tire Pressure
Tire Pressure
Ryan S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan S. Quote  Post ReplyReply Direct Link To This Post Topic: Tire Pressure
    Posted: March-15-2006 at 7:48am
I've heard it's best to run trailer tires at max pressure. In the case of my single axle, that's at 65 psi. Can anybody confirm or dispute this? Thanks
Ryan
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2006 at 8:33am
Back the pressure back about 5 psi or more. If the load isn't maxed out then you really don't need the extra pressure (rough ride) and as the trailer rolls down the road the tire will heat up a little and the pressure will increase some as will. Around 50 psi is where I keep mine.
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2006 at 10:58am
Ryan,
I've read max pressure Cold. Different than
reading while the tires are hot.
65psi sounds high to me, but it depends upon
the tires you're using. I think mine are only 35
but I have a tandem.
Agree they do bounce more with more pressure in
the tires.
BKH
Livin' the Dream
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2006 at 8:18pm
    I find running at rated pressure makes the trailer not so mushy side to side, especially at turnpike speeds. Underinflation can cause tires to heat up due to the extra resistance, making it harder to pull (even though you may not feel it). As far as ride, I find not a huge difference since the weight is there and the springs take it all.
                                  Jeff....
