Belt alignment |
jimsport93
Platinum Member Joined: February-20-2008 Location: Alpharetta Ga Status: Offline Points: 1750 |
Posted: February-21-2014 at 10:32am |
Take a close look at these pictures. The pulleys are not aligned properly. Belts are offset and creating belt dust. How do I fix this problem?
SNobsessed
This is a common problem; it wasn't highly engineered to say the least. I added a washer under the screw head, which rotated it into better alignment, see photo.
backfoot100
You can take a straight edge and lay it across the face of the water pump pulley and see how much you need to shim the RWP to get it aligned.
Some strategic washers/shims added to the mounting bracket at the block and/or the pump end will fix it up. You might need to get a little creative. |
Eddie |
shawn123
Groupie Joined: July-28-2013 Location: indiana Status: Offline Points: 67 |
Glad to see someone else has this issue. noticed that on my boat last year and starting thinking alt, water pump or something. Also glad to see its an easy fix.
if it floats it's not sunk
JPASS
I have the same problem on mine.
'92 Correctcraft Ski Nautique
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21172 |
You'd be amazed at how much the alignment improves if you keep a healthy amount of pressure on the pulley (pulling it starboard) while tightening the bolts.
Smithfamily
Platinum Member Joined: December-26-2007 Location: Orlando, Fl Status: Offline Points: 1602 |
92 Ski. Same issue fixed with washers. Like a puzzle.
Js
jimsport93
Thanks guy. Going to install a new belt set when I freshen her up with a new impeller.
Will work with a few strategic washers if needed. Usually use a pry bar on the pulley and alternator when tightening the belts. So, I'll give it a go and get her ready for the water. Won't be too long now |
Waterdog
Looks like some belt dust on the alternator too.
An 18in. straight edge is very handy tool and a half dozen thin and thick washers. Most of us have tackled this before. I bent a joggle in my alternator top bracket to get both pulleys into alignment. Put it together, take it apart - repeat. |
It even looks misaligned from the picture. Yes, washers, a straight edge and a tape measure are basic mechanic 101 tool. Don't forget there are directions (plains) for proper alignment. |
TX Foilhead
Ibadan that issue last year and Tim's right about the tightening stuff it, that would straighten it out. The problem was that also pulled the threads out of the pump which made it crooked again. After a couple of tries to get it to stay without pulling out the threads I went up a size on the bolts and and started with some fresh threads and everything worked first try.
jimsport93
Don, just sent you a PM regarding the dash pod (hi-jacking my own thread!).
JPASS
I was never able to get mine aligned right. I added washers and re-installed it several times with no luck. I just got fed up. I'll be replacing the impeller again shortly, so I'll try it again, but here's what it looks like presently.
JP, How much tension do you have on the RWP belt? If it's not excessive nor has never been bad enough to distort the RWP bracket, then some machining of the bracket will be needed to bring the mounting surfaces parallel. |
JPASS
Not much tension at all. I pull on the pump by hand to tighten the belt. I dont use a breaker bar or anything.
BuffaloBFN
Jim, Moroso made a nice kit of spacers. The washers work of course; sometimes harder to re-assemble. The kit comes in 5 thicknesses I think...I have a couple here.
Knock it back if you need the part #. |
baitkiller
Just a though fellas. Im not a Ford guy but the Chebbies circ pump pulley flange is a press fit and can be adjusted a little with a puller or hammer depending upon desired direction of said adjustment. Remove pulley, place cheap 5/8 or so socket over shaft contacting the flange only and give it a smack.
Is this perhaps also the case here? If you could romance that circ pump pulley back a few MM without hitting anything it would be sunshine and roses all around. That's how us hacks get pulleys to line up when a replacement pump doesn't line up when installed. |
