312 part help |
stang72 ![]() Platinum Member ![]() ![]() Joined: July-31-2004 Location: United States Status: Offline Points: 1608 |
![]() ![]() ![]() ![]() ![]() Posted: April-12-2006 at 4:43am |
I am looking for a source....in need of a front timing cover (crankshaft)seal for a rh rotation 312. Anyone know where to get one?
As soon as I get this I can fire it up after the rebuild. |
79nautique ![]() Grand Poobah ![]() ![]() Joined: January-27-2004 Location: United States Status: Offline Points: 7872 |
the rotation will not effect the timing cover so any timing cover for a 312 should work.
79....I have the timing chain cover...what I need is the seal. I think it is called a crankshaft oil seal.I am told that part needs to be for rh rotatation.
your correct the seals are different, depending on RH or LH rotation, but I believe that is only for the rear seal and not the front crank. I would check with Paul aka 67nautique312 or maybe reidp they know a lot more about the Chrysler engines.
62 wood ![]() Grand Poobah ![]() ![]() Joined: February-19-2005 Location: NW IL Status: Offline Points: 4527 |
79,
i think the 312 is a ford ..."y" block.. Stang, have you checked with an engine machine shop? The guys that did the machine work on my 283 got my reverse seal...now I just need time to assemble the motor... ![]() |
312....318... whats' the difference..
Oh, it's a Ford and Chrysler thing, I see ![]() |
