  New Posts New Posts RSS Feed - Shower and Heater Probs in ’85 2001
shoedad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shoedad Quote  Post ReplyReply Direct Link To This Post Topic: Shower and Heater Probs in ’85 2001
    Posted: April-22-2006 at 9:50pm
I just installed a heater and shower in my '85 2001 however I can't get any hot water. What do you think could be the problem?
When I drain water out of the bottom of the engine, the water is cool from there as well.
My question is this: on a 350 Chevy Engine is there a special thermostat that we need to be able to get the water over a certain temp.
If I'm idling, I can get my engine temp to about 100. As soon as I hit it, the temp goes below any measurement marks.
Any ideas would certainly be appreciated.
PLBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLBC Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2006 at 9:35am
engine temp should be warmer than that. try a 160 or 180 degree tstat.
99
AWhite70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2006 at 10:58pm
Where are you tapping in to get your water for the heater & shower? And where are you returning your water from the heater?
Sounds to me like you may have bypassed the thermostat with your heater. This will cause the engine to continuously circulate cold water and not warm up.
Please post some pictures of your installation or give detailed explanations of what hoses/fittings you tapped into.
