ProTec Ignition Swap |
Post Reply | Page <123 |
wkebrdr
Newbie Joined: April-08-2024 Location: 64078 Status: Offline Points: 1 |
I searched around, but what spark plugs are you using since going to the DUI?
Bill
92 Ski |
malcolm2
Senior Member Joined: June-13-2010 Location: Nashville Status: Offline Points: 235 |
I will have to check. I don't remember off-hand. I will get back here and reply with that. It has been quite a while, and I will say that this change was fan-dam-tastic. No more hiccups, super quick starts. ZERO ISSUES.
Autolite 764 or 104 plugs. 0.055 gap with the DUI.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10696 |
Since this is your first post, nobody knows whether your engine has the standard heads or gt40 heads. So..........the bestest, most correctest answer is to use the same plugs that are in it now because there were different plugs depending on the heads used
