  New Posts New Posts RSS Feed - Best oil used for a Graymarine 4-cylinder?
crabman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crabman Quote  Post ReplyReply Direct Link To This Post Topic: Best oil used for a Graymarine 4-cylinder?
    Posted: August-07-2014 at 12:53am
I know not another oil thread, but was wondering what most were using? Opinions wanted
I was thinking about going with BradPenn.
http://www.penngrade1.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2014 at 4:22am
I run VR1 20=50 in all my engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crabman Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2014 at 11:13pm
I was really thinking I needed to run a little higher Zinc and Phosphorus levels then normal. Just out of curiosity have you ever sent your oil samples to blackstone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2014 at 11:43pm
So I am not sure about the Gray Marine 4 but I run non detergent 30 weight in my 4 cyl Hercules (1956 Chris Craft). In my boat the engine oil also serves the transmission and anything with detergent or synthetic will do no favors to the transmission clutches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crabman Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2014 at 11:54pm
What brand do you use? I have a friend that has Caviler also, not a 100% sure of the year though, I believe it was in the 60's though. Bradpenn got back with me and need to call the rep back tomorrow about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2014 at 12:37am
I am not sure as my buddy that restores the oldies has a 50 gallon drum (think it is Napa) that filled up a 2 gallon can for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2014 at 3:25am
A non detergent has NEVER been recommended. I and hundreds of my fellow ACBS members have no issues. They created detergent oil for a reason!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2014 at 10:47am
Isn't it bad to change over to a detergent oil in an old engine that has always had non detergent?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2014 at 11:39am
If it has sludge build up, I'd say so... The detergent might free it up and circulate it. If no sludge, no reason to stick with non-detergent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2014 at 9:38pm
A 56 should have never been run on a non detergent.
