  New Posts New Posts RSS Feed - anyone Have Stand up PWC?
DayTony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Topic: anyone Have Stand up PWC?
    Posted: August-13-2014 at 5:52pm
I have an older PWC in my garage (not mine), i think its a 98 SXI pro 750
I pulled it out of storage from a friends and am attempting to clean it up and get it going for next season.
At this point i have taken the motor out and electronics, etc. it has a newer engine but i could not get it to turn over, i figured the motor is seized but after pulling it out I realized the shaft was frozen in the pump housing, the stuffing box bearing is free and the impeller seems clear of debris.
so my question is; Has anyone taken a drive shaft out of one of these before? I cannot get the pump housing to slide off the shaft and cannot see any type of set screws or c clips holding it back.
there seems to be no way of getting a puller over the housing either.
my only thoughts are to use a slide hammer on the engine side of the shaft but it seems sketchy.
1988 Barefoot nautique-454
05 210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 05 210 Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2014 at 10:07pm
The pump housing is sealed to the hull via silicone. They are a bitch to get off. Take the intake grate off, take the rideplate off, there may be 4 screws that hold the pump housing to the hull. Once that stuff is loose/out, the only thing holding the housing in should be the silicone. The shaft from the motor slides right into the impeller via a spline. . The impellar mounts into the pump housing itself via a threaded stub shaft that passes thru the housing bearings. The impellar cannot be removed from the housing until the housing is removed from the hull.
Or, you could do the right thing and just sell it to me cheap. I am looking for one of those
Mike
Air Nautique 210 Team
640 hours, not 1 regret
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2014 at 1:57pm
hmm i'm wondering if what you took apart was different than this because the pump housing came right off the craft no issues. four bolts into the hull and it dropped down, BUT the shaft itself will not spin or move in the housing.
here it is
did not seem to be any silicone in there at all.
the shaft does NT spin on this housing at all and will not slide off.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2014 at 1:57pm
To pull the housing off I have successfully used more than once a trailer strap and a lawn tractor or 4 wheeler. If its strapped to a trailer good a tree and putting the tow vehicle into drive also works but is more sketchy.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2014 at 2:08pm
ha, did something similar to that trying to get a frozen receiver out of a hitch, didnt end up too good for the truck.
i dont think thats an option here, maybe a slide hammer carefully wrapped around the housing?
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2014 at 2:17pm
The Kawi pumps are a 1 piece deal. Were you able to remove the prop? The shaft is threaded into the prop on the back end.
Usually what freezes up the pump is corrosion between the SS wear ring and the aluminum housing causing the liner to bulge and press against the prop.
Once you remove the prop, you'll be able to see how the wear ring area looks. These are not serviceable to my knowlegde and will need to replaced if bad.
I found the exploded view from
Here
Just Select Kawi watercraft, the year, make, then jet pump.
I'm getting the 500-Internal Server Error message, otherwise I'd post the view for you here.
I may know a guy with a used pump pretty cheap if you need one. Let me know.
'92 Correctcraft Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 05 210 Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2014 at 2:41pm
Tony,
Odd there was no silicone as Kawasaki was famous for using a tube of it around the pump to keep the ski from cavatating due to aeration. Non the less, if the pump housing is free from the hull it should pull off of there with a tug. The flat sided end in your pic is the back side of the stub shaft that the impeller screws on to. On the opposite end of the impeller there is simply a female spline with a seal and the drive shaft slides right into it. It must be seized on there. My guess is the bearings are junk as well due to sitting with moisture in them. As I stated earlier there is no way to remove the impeller without taking the jet pump housing off as it stays in the housing when removed. You hold the flat sided stub shaft (housing and all) in a vice, then slide a splined tool w/ hex head into the female end of the impellar to thread it off the stub shaft via a wrench. Then and only then can you inspect the pump housing wear area and replace those nasty looking bearings I see in your pic. I should have the tool at home if you need to borrow it once it is apart. Or, you could just sell it to me and I'll do it myself
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2014 at 2:44pm
hey thanks for that link, iI found a bunch of schematics online but having them all in one place helped out. I figured out where i was going wrong and was able to get it all apart. i didnt realize the pump was its own standalone untit. i thought the shaft carried all the way through.
i stuck a slide hammer on the inside end and was able to force it out. was frozen pretty bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2014 at 2:55pm
Looks like your impeller is making contact with the wear ring/pump housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2014 at 3:00pm
yes, The whole thing is getting replaced.
my friend is getting the full package or nothing at all.
new pump, new engine new carbs, motor mounts etc.
