  New Posts New Posts RSS Feed - help with 6.0 engine fault
Albertocsoares View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albertocsoares Quote  Post ReplyReply Direct Link To This Post Topic: help with 6.0 engine fault
    Posted: September-15-2014 at 9:14am
Please help
2010 CC200 - engine 6.0 lts - 970hrs
trouble code:
SPN: 91 TCP #1 Sensor Fault
FMI: 18 TCP #1% Lower than TCP #2%
Also noticed some oil debris in the flame arrestor
Thank you all !!!
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2014 at 4:34pm
Is the engine running? or just quitted?
what are the sympthoms?
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albertocsoares Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2014 at 5:13pm
Tks. It is running, the check light goes on and when we turn the engine off it resets. After a few minutes running the engine it goes on again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2014 at 6:11pm
I would try here
http://www.pleasurecraft.com/manuals/PCM-ECM-07.pdf
the first error code is something related to the throtle and tach sensor...
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2014 at 6:13pm
sorry bad link I will try to post it again
or give you the google search where I found it.
its basically a PCM service manual
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2014 at 6:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albertocsoares Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2014 at 7:23pm
Thank you Kapla, I will try to change the TCP sensor, it is not that expensive.
Best regards,
Alberto
watrski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote watrski Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2014 at 1:01pm
How are you pulling the codes? Our 6L has the check engine light also.
Tubing Sucks.
