Eric Lavine and Fantastic Finish Marine |
Author | ||
jhersey29
Senior Member Joined: February-20-2014 Location: Colorado Status: Offline Points: 272 |
Posted: October-29-2014 at 8:56pm |
Looks like Fantastic Finish Marine is out of business. Does anyone know where Eric Lavine ended up or some place I could trust to overhaul a PCM 40A 1.23 transmission?
JoeinNY
Eric had sold the business a few years ago. I do know someone that had a velvet drive built and installed there this summer though. - as to your transmission it has been a tough one to overhaul cost effectively due to the high cost of parts. Fortunately they usually dont break. What are the symptoms?
Jim,
Did you call FFM. I'm curious about FFM going out. |
jhersey29
The transmission ticks very loudly when put in reverse. Seems to run fine in forward with only one slippage that I have noticed. I'm worried something might break off when in reverse in do more damage if not repaired.
jhersey29
FFM's website does not work and the phone number I found does not work either.
74Wind
Am sure the wizards on the site will say it's the dampener plate or perhaps suggest adjusting the idle. Mine rattles a bit in reverse also but no slippage. |
1974 Southwind 18
1975 Century Mark II |
td_in_nc
Senior Member Joined: March-30-2012 Location: Clayton NC Status: Offline Points: 381 |
FFM did my transmission in August. I just called 877-369-6693 and it is still FFM.
Orlando76
Dampner should make noise in both directions. Does the noise exist at higher speeds in reverse? Just to check, raise your idle and see what happens. If it goes away at high speeds then maybe dampner.
Todd, I respectfully disagree. If a spring (or more) is broken on one end only, it's only loaded in one direction of rotation. |
Yes, but the damper only spins one way, right Pete? |
leetudor
Groupie Joined: August-29-2014 Location: Mount Juliet,TN Status: Offline Points: 96 |
Engine and drive plate only spin in one direction. The output shaft of the transmission changes direction.
Wow, I sure wasn't thinking! Yup, it only spins one way.
phatsat67
I thought the motor went backwards in reverse ;). Waiiiittt don't ours spin backwards anyways? Hahhaa
backfoot100
Zach, It's a 1:23. No spinny bacerds. |
Eddie |
phatsat67
I'm just messing with Pete Eddie ha.
Since lewy is down under does his backerds spinning engine spin the opposite ? |
phatsat67
Yes because the water swirls the other way off the propeller. Thats why the CC boats drive so much better in the northern hemisphere and not in the southern hemisphere.
Hollywood
Last I heard Eric was in the Florida panhandle working on tugboats.
What is your in gear (forward) idle rpm? A low idle will rattle the trans, more so in reverse than forward. Seemingly a larger "load" on the prop trying to plow the transom through the water while the prop swirls the opposite direction it was really designed to. |
jhersey29
It does become inaudible if I give a good amount of gas in reverse. At just idle(700 rpmish) it ticks about once every half second. No noise at all in forward. |
IAughtNaut
Grand Poobah Joined: August-22-2010 Location: TN Status: Offline Points: 2568 |
quinner
He left FLA, believe he is back in Ohio Try FantasticFinishMarine.NET ....FFM.... |
storm34
I agree with HW.
Hollywood
Make sure you have enough fluid in there. Read your manual on how to properly check it.
jhersey29
I called the number above (877-369-6693) and got a voicemail. Vince called back and I am talking with him. He was going to check in with his mechanic to see if they could think of anything. Oil level is good. It has 2 quarts and is right on the line.
Hollywood
Exactly how are you checking it?
Orlando76
I've heard it's hard to have too much fluid in it, at least with the velvet drive.
SNobsessed
The early Merc outboards had 2 starters - 1 would start it in opposite direction for reverse. I bet the drivers had fingers crossed when coming up to the dock in strong wind/current! |
jhersey29
http://www.correctcraftfan.com/Downloads/1999%20Owners%20Manual%20Ski.pdf Page 57 or section 8.6. Boat is level oil measures at top of dipstick. The dipstick is fully inserted. The specifications also call for 2 quarts and when I drained it a few weeks ago I sucked out just about 2 quarts and put 2 back in. |
For the convenience of all, here's a proper link |
