Wire Reinforced vs. Soft Wall Water Hose |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2978 |
Posted: November-23-2014 at 12:52am |
I'm replacing some of my 1-inch water hoses from the water pick-up up to the transmission cooler.
The question is whether to use wire reinforced or soft wall high pressure hose. I recognize that the OEM spec was the wire reinforced hose, but to my way of thinking, there doesn't seem to be much difference. The wire reinforced hose is a little tougher to deal with than the soft wall high pressure hose. Is there any real difference? Most of the hose runs under the engine inside the bilge area and there is no apparent risk of crushing the soft hose. Bends are not excessive and there does not appear to be a risk of kinking the hose. What's the issue then? Cheers, JQ |
The problem is with the hose collapsing due to the suction of the raw water pump,the wire stops that. I have found a heat gun helps when putting wire reneforced hose
Rob,
Confirming what Gary states, use wire on the suction side. It's NOT a danger of crushing but rather collapsing. |
Jonny Quest
Thanks gents. Wire reinforced hose ordered and on the way.
JQ |
