Dipstick hole in 351block |
Author | ||
jhersey29
Senior Member Joined: February-20-2014 Location: Colorado Status: Offline Points: 272 |
Posted: January-12-2015 at 10:00pm |
What does pcm use to fill the automotive dipstick hole in the block. It is on the port side rear in a moon shaped cut away.
jhersey29
JoeinNY
Mine has had a rubber hardware store plug in it for years - it's possible the industrial blocks didn't have them.
It looks like the casting is thick enough to tap for a taper pipe plug.
On some engines I have seen plugs that press in like a block core plug only smaller.
Waterdog
zacley, Small brass plug. If you want, put a little countersink on top & bottom and JB weld it. |
Welch plugs They do come in many sizes. |
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6149 |
Exactly what I had in mind Pete. |
I would also suggest using a hex socket head pipe plug. You could tap the proper depth and not end up with a protruding head. |
phatsat67
Even better idea.
Mountain Man
Senior Member Joined: May-09-2014 Location: Brevard, NC Status: Offline Points: 124 |
The Welch Plug if available is certainly the preferred choice. Saw the same question over on a Ford Mustang website / forum. One suggestion was to use a spent brass - 9 mm Cartridge casing. According to the information provided it is easily swaged into place using a hammer and a drift punch.
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2065 |
I went through this yesterday. I tapped it and installed a 1/8" brass pipe plug. no Brainer. Home depot had the plug.
Jody, I'm glad to hear that someone used a proper method of plugging the hole and didn't pound some old shell casing into it. I hope the person on that Ford site did mention to use a spent casing rather than a live cartridge! |
Mountain Man
The guy on the Ford forum with the spent cartridge casing idea had already buttoned up his oil pan and installed the engine before he found the second dipstick hole in his block and could not tap the hole without getting metal shavings in his new engine. I think he knew it was a hack fix because he joked about having a "bullet" engine rather than a "billet" engine...........
Fl Inboards
Never thought about shell casing. I had a bag of spent brass .38cal sitting right on bench.
