Engines not getting fuel. |
Tate
Senior Member Joined: October-08-2004 Location: United States Status: Offline Points: 134 |
Posted: May-09-2006 at 8:38pm |
Had the boat out for 3 days this weekend and it ran great until Sunday when it just stopped running. I'd just filled it up 30 min. before hand so I had plenty of gas. We pulled the hose off of the fuel filter and let it dump into a water bottle that we'd cut the top out of. There were some black specs in it but it didn't seem that there were enough to clog a filter although inside it may have been another story. The line out of my pump is pliable. The main fuel line going into the pump looks to be about 7/8" OD and has fairly thick walls. It is not pliable. It's pretty hard. Is this normal? Do the thick walls make it hard or is it time to replace this line? Do the black specs mean the line is breaking down? I'm trying to figure it out before Friday. Any help would REALLY be appreciated. Thanks.
Tate
Atmspltr
Senior Member Joined: May-04-2005 Location: United States Status: Offline Points: 170 |
Did you pull the inlet or outlet hose from the filter? I would guess if the boat has been sitting for awhile you may have transported varnish from the tank/fuel lines to the filter. I'd start by changing out the fuel filter first. I'd try flushing the fuel line through a cloth to see if the debris is coming from the fuel line. You didn't say...is the fuel pump electric or block mounted mechanical fuel pump?
Tate
I pulled the inlet hose. The pump is electric. If I flush the filter through a cloth, how much is too much (or is any too much)? Is the line supposed to be that rigid?
Tate
Atmspltr
I'd pull the outlet side and verify that the pump is moving fuel. There is a tight screen on the suction side of the fuel pump. If your getting debris, I'd bet that the screen is plugged and the pump is starved for fuel. If it is, pull the pump and clean the suction screen. That would explain why it ran fine and then quit. I bet it started as a loss of power at WOT and degraded to the point where it wouldn't run.
I don't know about your fuel hose hardness. It could be that it's breaking down and putting debris in the pump suction..good luck, RB |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5768 |
Tate,
If you take the fuel line and bend it does it crack? If so, replace it even if it's not your current problem. Pretty inexpensive from skidim. |
David F
The marine spec rubber fuel line is very thick walled and fairly rigid. It should bend ok, but not hardly give at all when trying to squeze it. Aviation fuel line is basically the same thing (Aeroquip).
jon4pres
Senior Member Joined: September-19-2005 Location: United States Status: Offline Points: 275 |
I have the exact symptoms that Atmspltr described on my 82. I took off the bulb to the water seperator and it was full of water that smelled like gas. My thought is that I probably got water in my gas tank some how. I am thinking tonight that I am going to try to drain the gas.
Is there anything else that I should do other than just put fresh gas in it after I drain all of the old out and check the screen on the fuel pump? |
quinner
FWIW, I had a similar problem many years ago soon after buying a 77SN w/351, boat was 10yrs old w/300hrs, ran great up to 32mph then it would sputter like it was starving for gas. I replaced filter, no help, Dealer replaced fuel pump, no help, rebuilt carb, no help. I started checking all the lines myself, removed the brass fitting at the top of the fuel tank, looked like anti-siphon or something, anyways it was clogged up bad, cleaned it out and never had another fuel problem again.
Good Luck |
jimbo
I'd remove the hose from the "out" side of the fuel pump or from the carb and crank the engine a few times to see how much fuel comes out (catch the fuel in something).
If there's flow, I'd suspect the gas you put in 30 min earlier. Maybe it had water in it? Maybe it was Diesel Fuel |
duffnit
Senior Member Joined: October-12-2005 Location: United States Status: Offline Points: 235 |
All of above. Does your boat have the screen filter at the carb? I'd check that also.
FWIW, on our older family boat we had a similar problem with the boat running and then shutting off. You didn't mention if it cranked up again or not. If after some elasped time it started back up and ran, I'd say you have the same problem we did. Replacing the fuel line solved the problem. Apparently after running at a constant speed the line would collapse and shut off the flow. After the boat sat a while it would crank and go. The warmer it was, the more frequent it would happen. As jimbo mentioned bad gas could definitely cause the problem as well. Just my .02 |
Danny
"no offense- but the rate at which you spread bad information is very impressive" |
Siveck
Senior Member Joined: March-14-2005 Location: Birmingham, AL Status: Offline Points: 100 |
Maybe that's what is wrong with my boat! I have been chasing this problem for two years. It will run fine at a constant speed for about 30-45 minutes and then it will sputter and die. After cooling off for a few minutes, then it will crank up and go for about 5 minutes and repeat for the rest of the day every 5 minutes. |
1975 Ski Nautique
"Small Letter Boat" |
