speedomotor pickup |
pdecraene
Newbie Joined: May-13-2014 Location: U.P. Status: Offline Points: 6 |
Posted: March-10-2015 at 12:08pm |
I have an 86 Ski Nautique, last year one of the speedos quit but I didn't do anything with it. When I pulled it out to winterize I saw that one of the pickups had the nipple at the top broken off and the tube was very brittle. Is there a replacement available for the pickup and tubing readily.
Hollywood
The Airguide model you have is no longer available but any pitot will work, be it a Teleflex or Faria brand. You will likely have to modify the mounting holes to line up on your boat.
dwouncmd
Gold Member Joined: July-10-2009 Location: NC Status: Offline Points: 919 |
I bought replacements from Discount Inboard Marine (SkiDim), I believe Christine's and N3 Boatworks (with 10% CCF discount) have them as well. I had to drill the mounting holes out a little and used plenty of 3M 4200 to seal. Problem solved (though now I am chasing a leak in the system on one side).
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7 |
chuckactor
Senior Member Joined: August-20-2013 Location: Ft Collins CO Status: Offline Points: 102 |
The nipple broke off one on my 85. I got a piece of stainless tubing from the hobby store that had about the same ID as the hole in the pickup. Cut a piece about an inch long. Just bore out the hole in the top of the pickup a little bigger to fit the OD of the tubing. I drilled maybe 1/2" deep. Then just epoxied the tubing in place leaving maybe 1/2" sticking out.
