  New Posts New Posts RSS Feed - Power valve selection
mamigacz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mamigacz Quote  Post ReplyReply Direct Link To This Post Topic: Power valve selection
    Posted: May-04-2015 at 11:45am
I thought it would be helpful to share some information I collected.
I recorded vacuum data (from a MAP sensor) while driving at steading state speeds (not accelerating). The graph I attached has RPM on the Y axis and vacuum on the X axis. I also added some reference lines to show when a 2.5 and 6.5 power valve would open.
My engine is modified with Cam research camshaft, GT40p heads and a performer RPM intake. A stock cam would yield a different curve (higher vacuum levels) than what I am showing. Also, I was the only person in the boat and not towing any skiiers. However it does show a good example of when a power valve would open to enrichen the fuel mixture.
pmt2234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pmt2234 Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2015 at 4:22pm
Many thanks for the data. Do you know your cam specs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mamigacz Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2015 at 11:00pm
Always glad to help!
intake lift .49
exhaust lift .49
intake duration 278
exhaust duratation 282
Intake duration @.050 216
Exhaust duration @ .050 220
lobe separation 112
