  New Posts New Posts RSS Feed - 318 Exhaust Manifold Question
PKster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PKster Quote  Post ReplyReply Direct Link To This Post Topic: 318 Exhaust Manifold Question
    Posted: May-20-2006 at 8:38pm
Hello Everyone...
I recently purchased a '68 Mustang with a 318 Chrysler. The man I bought it from didn't winterize it one year and cracked the manifolds. He had the engine professionally rebuilt. I bought it as is, still needing the manifolds installed. I bought them with the elbows. I started to install them when I discovered extra hoses. Here is where the question ocmes in. Do hoses go to the elbows AND the manifolds? What is with the copper tube? Is there a copper tube for BOTH manifolds? Does anyone have some pictures to send so that I can see what the correct installation looks like? Do the end caps get plugs or hoses attached?
PLEASE HELP!!!
Thanks for any help you can give,
Paul
The Lake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Lake Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2006 at 12:21am
Hey Paul,
Check out the reference section on this site. I think there is a manuel for a 67 Chrysler that should show the water flow and hookups. If you don't have luck with that, let me know, I've got a 68 manuel and I could send you a copy of that section.
Chuck
Walk on Water
www.coldwater.me
69 Ski Nautique
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2006 at 10:55am
paul, it's not that hard to sort out. Basicly there are two types of manifold systems, on one the water pass thru the mounting flange on the other it doesn't.
On the sytle you have which sounds like it doesn't pass thru the mounting you have more hoses. The water will tee at the t-stat housing feeding both sides. Then you have one hose that attaches to the manifold and there is another that feeds the riser/elbow from an outlet on the manifold, somtimes it's on the front of the mainfolds other times it's by the flange or mounting interface. So basicly you have an inlet and outlet on the manifold and a inlet only on the elbow/risers then it dumps into the exhaust hose and out the transom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PKster Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2006 at 11:29pm
Thanks Chuck, I downloaded info yesterday.
Thanks '79, I now am about half way through the installation process.
Appreciate your help guys.
Thanks again,
P
