  New Posts New Posts RSS Feed - Uprgrades and battery question
6strings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6strings Quote  Post ReplyReply Direct Link To This Post Topic: Uprgrades and battery question
    Posted: May-26-2006 at 10:39am
A couple of days ago I ordered breakerless ignition kit, coil, plug wire set, impeller for water pump, and a new acme #540 prop (great help from Skidim, by the way) for my 77 ski nautique. Can't wait! In the meantime, I plan to replace the battery and have gotten various advice on CCAs, Marine or automotive, deep cycle, etc. Would someone please advise the ideal battery for my 351 PMC? No stereo, or additional electrical equipment, just standard set up. Thanks in advance.
AWhite70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 10:45am
I don't have all the answers but I can provide some. for CCA's get something above 600. I think I have 650 or 675 in my '79 SN. Don't get a deep cycle. I can't remember exactly why but there was a good reason and most everyone will tell you to stay away from them.
I use automotive batteries in both my '79 and '02 and haven't had any problems.
79skinautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79skinautique Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 4:06pm
I run optima blue tops in both of my boats. They are a little expensive, but you will never have a problem.
Aaron
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2006 at 10:46pm
a deep cyle is low current over a long period of time, A starter needs high current over a short period of time. Get a 650 or higher CCA battery,choose a DELCO, OPTIMA or DEAKKA brand with a 60 month or better life.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6strings Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2006 at 9:39am
Thanks for the advice. I'm sure I'll have a few more questions once I get my parts and ignition kit. I really appreciate it! P.S. can't wait to get the new prop on....I think I have the original prop on the boat. Should be a world of difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6strings Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2006 at 8:38am
Put on the new ignition conversion. Very easy job with good instructions. Also put on the new prop (I think the old one might have been the original). Man, what a difference. The engine starts up right away, hot or cold, idles smoothly, and runs great at all RPMs. The new prop is so smooth, and running along around 2500 RPM and accelerating up to 3600 sets you back in the seat! It's incredible, like having a new boat! As I have read on this forum, electronic ignition and a new prop are the best bucks I've spent! Unbelievable!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2006 at 4:52pm
Optima Blue & Yellow tops are dual purpose, starting and deep cycle. I've but good things to say about these batteries.
