  New Posts New Posts RSS Feed - heater core
heater core
DayTony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Topic: heater core
    Posted: August-02-2015 at 11:46am
88 BFN.
Mine has what i believe to be an aftermarket but almost seems like it could be a factory optioned heater mounted in front of the driver. The hoses have been disconnected and i suspect someone didn't winterize it in the past and never hooked it back up.
question being, I cannot track down a new heater core. my radiator guy can't get one that is the same dimensions. it lists for a 70s ford f100. but is NLA and has no superseded part numbers.
the heater plenum box has a label that says Master mark Inc. lake worth fl. Model no. H-1 serial 89525.
core measures 6"x6" with the feeds both on same side.
plenum box measure 7.5" x 6.5" x12"
The part number i get when i look up the core is 91577 in Balkamp catalogue
Only option i have found is I can buy a 6" x 9" core and do some fabrication work to the box but i would rather not.
Anyone found a replacement for theirs?
1988 Barefoot nautique-454
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2015 at 1:10pm
Did you try googling heater core ford f 100?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2015 at 1:18pm
yes, the problem is the f100 core now comes up as its newer larger counterpart on anything that is current. so i'm guessing they made a upgrade at some point that fit the f100 plenum.
the only place i can find the smaller 6x6 core(not including tanks) is if i look in the older out datedd books. but any tries at cross referencing the number from the old book gets me nowhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2015 at 1:21pm
i got that number from belkamp which lists it from a company pro source which listed it as NLA according to my radiator guys. but thats the only source i have been able to find to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2015 at 3:34pm
Tony,
Have you looked into replacing the heater? Sometimes a part can be more expensive than the complete unit. You'd get a new blower too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2015 at 7:36pm
That was also my thinking. I jave not looked into them because its really not something i NEED so much as something i wouldnt mind having it work. But its one less thing i have to deal with when winterizing at this point. But its been sitting under my workbench since i got the boat and thought i might give it a shot at repairing it.
I will check out new ones tonight since i havent yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2015 at 9:42pm
I found a place on the internet that had cores,and there is more than one due to the angles of the pipes,but like Pete says a new heater might be better they were 190 each! Mid fifty.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2015 at 1:39am
Master Mark was OEM. Just get a new core/box/blower unit
