Waterline, Draft |
Duane in Indy
Posted: November-27-2015 at 12:27pm |
My Mustang 17 has the same sluggish symptoms at lower speeds also. Knowing that I was going to replace the stringers when I bought it, I started checking the foam in several areas. Foam looked good for the most part. Then I dug deeper. Against the hull it was saturated for at least an inch. Directly under the floor and several inches deeper it showed very little indications that there was a problem. Point being, dig all the way to the hull before making a judgement. Bet I have pulled out 400 pounds of saturated foam and waterlogged rotten stringers. Wished I would have weighed the boat for a before and after weight.
74Wind
Agreed but Only meant in broad numbers,
But weighing should be able to tell if it is grossly over weight. If he posted a photo it would help. |
1974 Southwind 18
1975 Century Mark II |
I think Tim's method would be the only true way to find out. Weighing one would only work if every boat weighed the exact same as the one the factory weighed. What if he weighs his and its say 30 pounds over? Is it wet or was more glass and resin used?
74Wind
Actually that can be pretty accurate, once with boat on trailer, then once with empty trailer. Subtract trailer weight then compare to original specs on reference page. |
1974 Southwind 18
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2863 |
It's called a "Plimsoll line". The Plimsoll line is a reference mark located on a ship's hull that indicates the maximum depth to which the vessel may be safely immersed when loaded. This depth varies with a ship's dimensions, type of cargo, time of year, and the water densities encountered in port and at sea. JQ |
Todd,
many have pulled their boat over a truck scale and then compared the result with the weight spec. It's not real accurate but it will indicate a wet foam problem. |
Tim D
Take the back seat out. Dig in the foam at the back corners or go under the dash in the center and stick something in the foam and see it it's wet down there. Full tank of gas, back shouldn't sit more than about 3 1/2" below water.
Tim D
