  New Posts New Posts RSS Feed - 5 inch cutless bearing?
mikestoner93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikestoner93 Quote  Post ReplyReply Direct Link To This Post Topic: 5 inch cutless bearing?
    Posted: September-18-2015 at 5:58pm
I'm currently trying to use the internets to find a 5 inch, but all i am seeing is 4's and 6's. When I pulled my worn out one it had a 4" and a 1" in it. Can i cut down a 6 being super careful not to tear up the rubber? or is that a no-no?
Asking for some quotes from some manufacturers who offer custom sizes as well. not sure how long that will take but looking to get done asap... boat has been outta the water too long right now haha. < I assume this is probably my best bet though.
Its a Skylark and the shaft is 1 and the strut is a 1 1/4 and the length of the strut is 5.
I tried to be awkward once... Just to see what it felt like...
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2015 at 6:06pm
cut to fit would work
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikestoner93 Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2015 at 6:09pm
okay
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2015 at 6:47pm
All you really need is the 4"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2015 at 7:05pm
flush to the aft edge of the strut
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2015 at 7:35pm
Correct and agree. A PO hacked it.
Since the cutlass has been changed before and now again, I suspect there may be an alignment issue. I suggest a complete alignment from the strut forward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikestoner93 Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2015 at 5:25pm
yeah the motors already unbolted from having the transmission out, so ahead of you there on re-aligning everything haha
