Acid Wash now or later |
Blamey
Gold Member Joined: August-18-2015 Location: White Plains,NY Status: Offline Points: 631 |
Posted: September-24-2015 at 5:28pm |
My Sport Nautique has some pretty bad water/algae marks on it. Any issues with waiting until the spring to get this taken care of? It's currently at a Marina where I can get it acid washed, not sure if I'll have time to do it before it gets too cold.
I want to try do some restoration on the hull, gel coat repair and maybe a acid wash , wet sand, compound and wax but will probably wait till the spring to do it (as winter is coming). Any harm is waiting to do the acid wash until I can do it all, the Marina doesn't wax the boats after the acid wash, which I have heard can leave them exposed. Here is a pic. |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6130 |
I would do it now. The acid wash is pretty powerful and effective and would probably do just fine in the spring, but even fiberglass has some degree of porousness, and staining could occur left there for 6 months, so why chance it. Not an expert by any means, just my opinion. I used to leave my boat in the water all summer up in ny and always acid washed it in the fall as soon as it came out.
BTW: I like the clean simple lines of that boat. Where in NY are you? |
skutsch
Grand Poobah Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
I think you might be surprised at home much of that will come off with basic Hull Cleaner. I had much worse staining on the Bass Nautique. I tried some wax, some serious elbow grease and couldn't get it to budge. After talking to TRBENJ at Green Lake and taking his recommendation, I was SHOCKED how it pretty much melted away when I sprayed it with some cheapo hull cleaner. Will try and post Before and After pictures.
75 Tique
Along the lines of what Steve just said, I never used a marina acid wash, I just used On & Off, which I believe is Tim's preferred chemical as well. Still an acid, and a pretty stout one, but it is a do it yourself at home operation.. You control the timing. It can be a little unpleasant under the boat, as I have spent some time on my back with the junk dripping down on me. Proper PPE is advised.
halfnelly
Senior Member Joined: January-14-2013 Location: Maitland, FL Status: Offline Points: 253 |
+1 for MaryKate On & Off. Just keep it off the boat trailer and wear some long gloves. Those stains will turn white before your eyes.
Paul,
Since you plan on a wet sand buff come spring I feel it really doesn't matter when you acid. As Larry mentioned, gel is porous and any staining that may happen over winter storage will come out with the wet sand. I've had very good results with the off the shelf acid based hull cleaners. It does open up the pores and seems to stain quicker in the water so a waxing is very important. |
Blamey
Great, I'll leave it as is for now and get it shiny in the spring. |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5779 |
never put off til tomorrow what you can do today.
the hull cleaner is maybe an hour job and then you can dream about your nice clean boat all winter. As stated don't get it on any painted surface, decals or your trailer. keep the hose running right next to you in case you do. |
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2207 |
I am a fan of the On / Off cleaner. I use the liquid as opposed to the gel. I cut it about 50/50 and spray one side of the boat and return with a sponge and hose to scrub and rinse.
As a precaution I would always wet down the trailer and driveway prior to any application and have the hose running why scrubbing. The PPE with quality gloves and safety glasses if you are on your back are an absolute. I would be applying wax shortly after the hull was clean and dry. Good Luck |
'88 BFN |
SNobsessed
One advantage of having the marina do the acid application is (I assume) they will lift it off the trailer. Then you don't have acid eating the trailer paint. Plus they get under the bunks too.
Hollywood
Never assume a marina will do something the way you want it done! Spell it out exactly.
Blamey
Well I don't have a trailer yet, so that wouldn't be an issue. Hoping to get one from Tim B/Scott next month and then will go get the boat and bring it down state. I also don't know if the trailer will fit up my drive yet. Drive is about 95 to 100 inches wide with a bit of a kink at the end. With it fits or not will be a matter of inchesinches. if I can get the trailer to the back of the house then I can store the boat here for the winter, if not I'll have to find some where to keep it. So basically I'm not sure where it's going to be and if I'll be able to do a wash before it gets too cold. , So my problem is really if the Marina doesn't do it now it likely it will have to wait until the spring. If I can get the boat near a hose before it drops below 55 I'll clean it myself.id rather not pay $300 to the Marina for something that wouldn't take me more then a 2 or 3 beers (I'm a light drinker). |
scootdogydog
Senior Member Joined: November-03-2013 Location: Central MA Status: Offline Points: 404 |
Paul, the trailer is 8'6", but the tires overhang the fenders, so maybe 8'8" iirc. It just barely fit into a 9' trimmed garage door
Blamey
Scott, That puts the total width at about 102. I was hoping it would be a bit smaller on an older trailer. It may still fit but I think it's going to be real tight. It's definitely not going to work for the summer but maybe if I remove the gutters from the side of the house and put on some biscuit tires I'll be able to get it back there. Either way I'll know next month. |
Smithfamily
Platinum Member Joined: December-26-2007 Location: Orlando, Fl Status: Offline Points: 1602 |
That stuff worked great for me! Followed by some marine wax. Careful though with the fumes! I |
Js
dwouncmd
Gold Member Joined: July-10-2009 Location: NC Status: Offline Points: 919 |
I use The Works toilet cleaner. The Works toilet bowl cleaner, 10-20% Hydrochloric acid (some bottles 10% some 20%). Usually $1-2 for 32 ounces vs. $12-15 for Star Brite, which is 5-10% oxalic acid. I dilute it with water and spray on with a bleach sprayer. I also like the idea of "painting" or sponging it on to avoid getting it somewhere you don't want it. Protect anything painted or metal, don't use it sitting on concrete (it will dissolve concrete). It seems to work better on a damp hull. Wear long (kitchen type) gloves and avoid getting inside the gloves. Whatever you use, give it time to work and you will be surprised by the results.
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7 |
SNobsessed
I used a brush mounted on a 3 ft stick. I put a paint roller tray on the floor under the boat to get access to fresh acid quickly. However, I had the trailer pulled out from under the boat, so this may not work when on trailer.
