Removing Perfect Pass |
SteveHookEm
Senior Member Joined: July-17-2015 Location: Houston Status: Offline Points: 157 |
Posted: October-09-2015 at 4:52pm |
We have the Perfect Pass. Never use it at all. I'm not that good of a skier. haha
It seems like more of a hassle to me right now. It draws a lot of power it seems, the beeping drives me crazy. I'm thinking of pulling it out. Is this too much to mess with? Should I just leave it in? |
SteveHookEm
I'm thinking of replacing it with a Precision Star GPS Speedometer.
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Online Points: 2957 |
The Precision Star GPS speedo is a nice unit.
SteveHookEm
@Jonny Quest Do you know if it will fit the space left if I pull the Perfect Pass?
a0128
Senior Member Joined: May-05-2014 Location: Oregon Status: Offline Points: 226 |
Assuming your PP has a 3.5" bezel (which it probably does) then the PrecisionStar will fit. You will want to order this one. I would try and determine why your PerfectPass beeps. Do you turn it off when you are just cruising, or otherwise not using it? I know with mine, if I leave it on (engaged) but just cruising it will beep and try and hold what ever speed I have set. I usually turn it off if I am not going to wake board. I have also read where these units will beep if voltage to the unit falls below a certain level. PP has a great customer service department that can help you if needed. |
If money can't buy happiness, explain beer and boats.
Bri892001
I have also read where these units will beep if voltage to the unit falls below a certain level. .../QUOTE] This is definitely true. The Perfect Pass does not like low voltage. The constant beeping was annoying. Shutting it off would cure the beeping until the next stop and start up. Also, you'd have to catch it "on" long enough to actually shut it off. With the motor not running, it used to be tough to even do that. This video will show you how to get to the Perfect Pass read system voltage. AKA, how much voltage PP is seeing. No multimeter required! Skip to around 9 mins to get what you're looking for, at around 10 is where they get into the voltage specific stuff, but you have to start watching a little sooner to see how to get into settings: https://youtu.be/LhnSoaJdV_I This is how bad my Perfect Pass was before I beefed up the dash wiring: https://youtu.be/g8gvTCmg9Og |
Jonny Quest
The Precision Star GPS speedo fits just fine in the standard 3 1/2 inch mounting hole. That is the same size hole as the Perfect Pass unit and the Air Guide speedos.
JQ |
