Floor maintenance time |
gmars70970
Senior Member Joined: November-06-2013 Location: Scotland Status: Offline Points: 235 |
Posted: August-01-2019 at 11:45am |
On a roll at the moment :)
6 layers of fibreglass so far, another 1 or 2 layers to go, its not as pretty as some of the work i've seen on here but it will defo be solid. Used 10kg of 2 part polyurethane liquid foam so far and still got the bow to fill. |
gmars70970
I'm only about 3 miles away from Irvine...…… Bring your tools as i'd imagine this will still be a work in progress when you visit lol |
1993R
Groupie Joined: July-27-2005 Location: Hawthorne, FL. Status: Offline Points: 46 |
You have to get this done before I visit my relatives again in Irvine.
You have had a good summer there so I know you are itching to get the boat back in action Seriously keep pressing on. Cheers Larry |
gmars70970
After 3 YEARS sitting in the garage im finally getting somewhere 👍👍
gmars70970
Cheers
Think i'll go ahead and give it a go. Might find an old joist to practice on first. tho. Really want to be able to say "i did that" when its renovated and back in the water lol |
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1412 |
Graeme
Yes it can be done on a hand router using the old as jigs… if you get yourself a half decent jigsaw and good blades and finish to shape with a hand belt sander 40 or 60 grit your find the nose wheel on the sander will sand the big rads your soon get the feel of it…do a few practice bits on off cuts, this may be better for you if have low woodworking skills. Good luck with the build Roger. |
Lets have a go
gmars70970
Another good mornings work on the stringers.
That's the engine cradle and one of the main stringers out. Wood work isn't my strong point, so I need to make a decision about do I buy a router and make the stringers myself or find a joiner to make them for me. Surely cant be that hard since I have one to copy???? |
MechGaT
I bet this has been on the back of your mind for a while. Good luck getting her done.
'92 Sport Nautique
gmars70970
After a SERIOUSLY long lay off from the refurb, a change in employment,
I FINALLY made a start on the stringers today again. The secondary stringer came out whole, hopefully the mains are the same |
gmars70970
Getting somewhere now !!
Still to level the boat up and start cutting, but that's all the cables out the way now!! ] |
gmars70970
Yip, that's it tucked away for the winter. Just to tidy the garage up a wee bit then level the boat up & it's time to get started.
I've ZERO experience of fibreglassing so feeling a bit nervous about it. |
gR@HaM
Doing it in your garage Graeme? Nice winter project!!
'82 Ski Tique
NCH20SKIER
Good luck. Keep us posted
'88 BFN |
gmars70970
Yeh I'm really not looking forward to it |
yuck
gmars70970
Finally got the engine out today !!!Been putting it off and off and off. But got it lifted out in 5 mins with a forklift.
Now the real work starts!!! |
gR@HaM
Well done Graeme, I'm looking forwards to following the progress..
'82 Ski Tique
gmars70970
I think its the angle of the picture making it look light. I was thinking of putting another cross beam on top of that one to double up for more strength.
Graeme,
From the picture, the top horizontal member where you will be attaching the means of lifting the engine looks pretty light. Do check it since I'd hate to see it bend with the weight of the engine on it. |
gmars70970
Thanks.
I'll get some eyebolts sorted out this week and get it lifted out. |
fore end of starboard head and aft end of port head should have rings screwed in, but there are many ways to lift and engine
gmars70970
Eventually got a frame built to remove the engine!!
Are there designated lifting points or can I just sling right round the engine? |
gmars70970
We have Craigslist but it's not really well used in Scotland.
I managed to get my hands on an old block & tackle today 👍🏻 also talked a mate into giving me some scaffolding to build a frame so hopefully have the engine out soon. |
Dreaming
a cherry picker works good for removing the engine... check craigslist and find one for a hundred bucks or so. you'll need to keep it around to put the engine back in, so find one that is "folding". the legs come off of these versions and store in the base of the hoist. You'll need to take the tire off of the trailer to get the engine over the gunnel, so don't forget that part before you start lifting
edit: I didn't check your location first... hopefully Scottland has a craigslist of sorts |
gmars70970
Finally getting back into the stringer repair. Removed the fuel tank & mufflers yesterday 👍🏻
Full of motivation at the moment, so just to figure out how to remove the engine and its full steam ahead over the winter months. |
uk1979
A few ideas on stringer material in the UK. Yes you can go with Douglas fir up in Scotland should be some around home grown... no need to be all planed up straight off the saw is good will give a better key when bonding. Here in the UK we have Accoya treated wood ( it’s a type of pickling of wood ) that can take glue/epoxies to bond, has a 50 + year warranty against rotting but it’s not cheap soft wood is around the cost of oak. We also have lots of Jarrah laying around which we plundered from OZ back in the early 20th century most was used as rail way sleepers and come in at 10ft long which is a bit short but you can find longer ones used at points... The cool thing about this wood is its ability not to rot as the tree sap/wood has a mild antiseptic that rot hates, the down side is its very dense so hard to cut so you would need to have someone with a band resaw to size, should get 2 stringers out of one sleeper @ 11’x6 inches 10ft long ones go for around £25.00 the outside may look bad but its only the frost over many years inside the wood is good. Composite can be made here too, last I checked Coosa is not here in the UK, but high density foam sheets are,..rule of thumb if an engine bed is on the stringers you need 30 Ib + for core foam do it in two layers so you can run a fibre glass roving /or biaxial cloth down the middle and stagger the foam joints side to side as foam come in around 8x4ft sheets. I would research the fibreglass system you have at work... I think your Idea of Cloth/biaxial and spray would be just fine you just need to know what you can use with the work system polyester, vinyl , epoxies I’m all for using what’s to hand with a few tweaks. Keep us posted Roger. |
Lets have a go
Frank,
Welcome to CCfan. If you haven't already, take some time to search out the site. There are a couple members who have done fantastic composite stringer jobs using Coosa. The sites search feature isn't the greatest so I suggest doing a "google" search using correct craft fan and coosa as key words. Lot's of instructional info and pictures in their threads. Keep the pictures coming. I also feel starting your own thread on the your project would keep everything focused |
Pete This must put Correct Craft in the "somewhat cheap" category these days since they use a combination of hand layup and chopper gun construction according to info put out by Correct Craft themselves KenO |
snob206
Newbie Joined: February-13-2016 Location: Ohio Status: Offline Points: 1 |
just pulled rotten wood all of it; next step is to remove foam; I am planning on using coosa board for stringers and floor supports; not sure what to do about foam |
frank
gmars70970
This is exactly the sort of advice I'm looking for! I'm totally new to working with fibreglass and didn't realise the chop system was different to the traditional method. Since I'm as far into the project I don't want to cut corners for a sub standard refurb. All advice is appreciated |
