Mustang 17 rebuild |
Post Reply | Page 123 5> |
Author | ||
Duane in Indy
Posted: January-24-2016 at 3:32pm |
I have finally finished up the stringer and floor replacement job in my '78 Mustang. Not ready to do another one of these for a while. Will be building seat frames next. Re-gel top and bottom and then it will be on to updating and freshening the engine. Last pic is of the other "Mustang" I work on a 1979.
1978 Mustang (modified) |
Duane in Indy
Front seat frame is fabricated all but the aluminum sheets for the upholstery to go onto. I will weld them into place and then clean up the weldment. Used 1 X 1 X 1/8 wall aluminum tubing. Hope to have rear seat frame done Friday and then deliver to upholstery guy Saturday. MUCH lighter than the original. Opted for a full front seat instead of 3/4 because it will fit our needs better. More pics to come. Duane
Duane,
Nice fab job. keep the pictures coming. |
Chevy350
Gold Member Joined: June-24-2013 Location: Illinois Status: Offline Points: 721 |
Seeing this makes me want to get my dad and I to redo the floor on our mustang.
1972 Mustang
Duane in Indy
Heading to upholstery shop with the front seat. Pics show frame only and frame with rigid backup foam. Original foam to go back in..
Duane in Indy
Was busy today punching holes in the rear seat back. Punched over 200 1 5/16 dia. holes Trying to keep everything as light as possible without compromising strength. Will try to do the seat bottom tomorrow. The back seat bottom will hinge forward so as to access rear bilge area. The seat back "keyholes" in on some pins. Ordered upholstery material yesterday. Blue.
Duane in Indy
Been busy since dropping stuff off to the upholstery shop. Fabbed up an engine cradle. The original setup was nothing more that a chunk of 2 X 4 cut on a 15 degree angle and lag screwed to the stringers. This set up will get cross bolted and lagged to the stringers. I will bed the cradle to the stringers with thickened epoxy prior to bolting down. Going to glass bead my mounts also. Should be a lot stronger and will spread the load out.
Orlando76
I like the cradle. Why not fab it up to brace the pylon too, wouldn't be much more effort?
Duane in Indy
Pylon mount already in place under floor. Bedded in and bolted down and in socket in hull |
Duane in Indy
Finished shot of pylon
LeftFieldEngineering
Senior Member Joined: December-20-2010 Location: Monson, MA Status: Offline Points: 384 |
Love the fab work,
SNobsessed
Wish I could weld like that.
Nice work! |
Duane in Indy
Been busy making wood shavings instead of metal for a change. Made my new dash panel from some Poplar that I've had in the loft to 25+ years. Planed it down and then put it on the mill. Stain, acrylic urethane, sand and buff. Glove box cover is not sanded or buffed yet. Wiring will start soon.
Fabcon
Gold Member Joined: August-27-2012 Location: Buffalo. Mn Status: Offline Points: 552 |
Very nice fab work.
1984 Barefoot Nautique (Parting Out) |
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3391 |
That is some nice craftsmanship!!
Duane in Indy
Thanks for the compliments.
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1797 |
That's some sweet aluminum welding partner. I'd be more specific but I know what happens when I use language like filet weld and butt weld.... Quinner has some sort of alarm system that goes off and, well.... You know what I mean.
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1721 |
Nice work. Both the metal and dare I say it? Wood.....works!
Great looking work Duane.
backfoot100
DAYAM!!!!! That's some nice work. Very sweet.
Eddie |
Smithfamily
Platinum Member Joined: December-26-2007 Location: Orlando, Fl Status: Offline Points: 1602 |
Very impressive! When we gonna have her in the water? Summer is approaching!!
Js
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5311 |
Looks like maybe I shoulda took another couple of years of woodshop back in High School. Beeeeeeeeeeeautiful! Nice Persian rug too!
On a second note.....I was looking at the stern pictures a little closer at the top of this thread and noticed the OEM air ducts back there. I replaced mine with flexible RV waste line I got at Walmart. It's basically the same stuff that's in there just black. Copper wire reinforced and TOUGH Vinyl.. It was a chore getting it on the scoops but I won the battle. Mine was mildewed real bad and dry rotted just as bad. |
Yes but one think they wouldn't have taught is how to use a insert fly cutter in a vertical mill (Bridgeport) on wood!! |
Duane in Indy
Pete, You have a clever eye. Also when we were in wood shop they had not invented the insert carbide cutter yet!! As I had told you in a PM, that I also built that insert cutter years ago. Bridgeports and wood don't really go together, do they? LOL |
Duane in Indy
I made a note of your suggestion on RV hose at Walmart when you first posted it and even went there to check it out. Found two thicknesses of hose. Thanks for the suggestion and big thanks to you and all others for compliments. Rebuilding these old boats is like eating an elephant, one bite at a time and you'll get there |
You must be a couple years older than I since I remember the inserts were just coming out. Back then, we would have had to been creative at the tool grinder and use one of these: |
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2205 |
When I was doing the Chris Craft Wenfound some ducting the local race teams (nascar) use to cool the breaks - if I recall it was 3" black and pretty stout (yet flexible). Spendy though when it is sold by the foot
'88 BFN |
There's a reason Correct Craft used dryer vent,when you say boat,airplane or racecar you know what that does to the price
Duane in Indy
Interior is all at the upholstery shop so I started working on the engine some. Went with FLOTEK heads. They are a really nice piece. Very little core shift. I have port matched them and did a mild port and polish job. For the money they are hard to beat plus you save about 40 pounds over stock heads. They can even be painted blue to suit the original folks..
Duane in Indy
Port matched and opened up the exhaust manifolds/heat exchangers. The ports were really restricted. Have to be careful not to thin the walls too much. First pic shows how small the port really is. Second pic is opened up considerably, the shadow in the rear makes it look like a big restriction in there but is only a shadow
