  New Posts New Posts RSS Feed - pitts. pa. get togethers
wfdavis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfdavis Quote  Post ReplyReply Direct Link To This Post Topic: pitts. pa. get togethers
    Posted: March-06-2016 at 8:54am
any get togethers in pittsburgh pa. area
wfdavis
AAM196 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2016 at 12:22pm
Hey Bill, it is a rarity but has happened.. lol. Where do you reside/boat? I don't keep my boat in the river, but frequent the Ohio a pool down from the city but have been all around Pgh.
JHadji View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JHadji Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 12:40pm
Hey - is there an engine mechanic you recommend nearby? Pleaseurecraft 351W
1988SkiNautique2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 4:10pm
What's the problem with the motor.
More info needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 4:38pm
More info needed.
Hot engine restart problem still??
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 4:59pm
Thanks Pete
John where are you located I could probably help you out on some minor things like the carb problem and such.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 12:01pm
Bueller ... Bueller :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote JHadji Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2017 at 3:09pm
I'm north (Gibsonia). Details: it starts up and runs fine, but when I shut it off hot (like to pick up a skier) it won't restart. It turns over at first but then tends to lock up after a few tries. If I wait until it's warm, it'll turn but not start. Eventually, when it's cool, it'll restart. The only diagnosis I've done is to pull the plugs and there was no water. It might be the carb or starter or both or worse. Unf I'm not an engine guy. It's all original w/electronic ignition I did myself (thanks to you guys here) and regular maintenance.
1988SkiNautique2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote JHadji Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2017 at 3:16pm
Would love to find a go-to mechanic I could trust nearby. If not, with a little wisdom from the sages around here, I've not been too afraid to change parts on my own.
1988SkiNautique2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2017 at 3:21pm
When you did the EI, did you check the timing? Timing too far advanced will cause starting problems.
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2017 at 7:01pm
I was thinking timing as well...
Post Options Post Options   Thanks (0) Thanks(0)   Quote JHadji Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2017 at 8:04am
Yeah, adjusted it at the time but it's been a while and pretty easy to check again. Will let you know.
1988SkiNautique2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2017 at 11:05am
John I'm just outside of Mars off RT 228 I could give you a hand figuring this out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2017 at 11:08am
While hard to diagnose without being there... sounds timing related. Has this always happened since the EI upgrade?
If you are unable to fix yourself, I'd go to Johnny's Marine Services, 88 Factory Street, Monongahela, PA.
Only PCM mechanic I'd trust.
AFTER PAUL of course! A pack of smokes and a 6 pack will have you sorted!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2017 at 11:44am
Thanks Andy but I don't smoke anymore been over a year now.
A case of Molson Canadian goes a long way still
Oh yeah   LETS GO PENS !!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2017 at 1:42pm
Good for you paul!   But I don't know if I trust a mechanic who doesn't smoke...
Let go pens!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JHadji Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2017 at 2:33pm
Paul - that'd be GREAT and you're really close. My email is jhadji2@yahoo.com. I sure do appreciate your offer to help me troubleshoot!
1988SkiNautique2001
phrnjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phrnjohn Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2017 at 8:46am
Would definitely like to see something happen​ here in the 'burgh.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2017 at 10:09pm
Look's like we're getting quite a few fans here in the 'burgh guess we'll have to start looking at some dates.
I'm heading for DCL tomorrow for a week but will be good after the 28th.
John I see your a nurse how is your during the week availability?
Where do you usually go? A friend of mine from your area and I have been hitting the pool up by the Fox Chapel yacht club.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2017 at 9:08pm
While we have a ton of thing going on, always, I am always down for something! Anywhere within strikin distance of city works! Fox Chaple pool is nice..
Copyright 2019 | Bagley Productions, LLC
