New Automatic Bilge Pump or add a Float Switch? |
Siveck
Senior Member Joined: March-14-2005 Location: Birmingham, AL Status: Offline Points: 100 |
Posted: April-26-2016 at 12:39am |
Thanks for the info. I had no idea that there were installation guidelines. I can't remember which direction it is pointing. I made a bracket and mounted that to the ski pylon thru bolt if I remember correctly. If I ever take it back off or have further issues, I can mount it correctly.
1975 Ski Nautique
"Small Letter Boat" |
Yes, my mistake. The float should face aft. Tony, thanks for the correction. |
DayTony
Gold Member Joined: June-30-2013 Location: Salem MA Status: Offline Points: 832 |
actually they want it to face aft. I always thought the covered models are more so stuff doesn't get stuck under it or on top preventing it from operating. In the past I have had to make wedges to mount to the base of the switch to modify the on-off positioning on the float to where i wanted it. |
1988 Barefoot nautique-454
Anthony, If you ever install another Rule float switch, they have some pretty specific install guidelines such as max mounting angles and it must face forward. They also have a covered model to reduce "wave action" in the bilge. |
DayTony
In the fish which i keep on mooring, I run a rule 1500 main pump on the rule super switch which i change out at the beginning of every season. The backup is a rule automatic 750 forwar the engine for emergency. I also have a second 1500 on standby ready to crimp on if needed in an emergency.
Both pumps are wired on a completely separate switch and circuit altogether. this way any failure with one will not effect the other. A friend's boat almost sunk because his high water alarm shorted and blew the fuse. Well the bilge pumps were on the same circuit and high water alarm never sounded, pumps never activated. Luckily he noticed his economy was wayyyy down. popped the hatch and water was almost over the engine. some scary stuff. the following weeekend I rewired my entire bilge pump circuit. my bfn if memory serves correctly the bilge pump was wired so it would not run if the "ign" switch was off. unless my factory wiring is messed up. I have never really left it in the water always on a trailer so i never addressed that problem. As long as your able to shut down all other electronics on the boat and still have the automatic switch fire the pump you should be good for quite a while with a fully charged deep cycle Group 27 in there. |
Siveck
It was the Rule brand and yes, it was short cycling. However, that was almost ten years ago and the design could have been improved since then.
1975 Ski Nautique
Anthony, Whos brand float switch did you use and what was the buoyancy issue in choppy water? Was the problem short cycling with the choppy water? I've used several of the Rule switches and they have plenty of hysteresis preventing the short cycle. It would be great to know the brand of switch you used so I and others can avoid the problem you encountered. |
Siveck
I installed the switch years ago like the one pictured in an above post but it had buoyancy issues in choppy water. Long story short, after nearly sinking overnight, I zip tied a keychain float to the switch lever and it has worked very well since. I just wired it inline with the current wiring. On at the dash and wait for the float. Simple.
1975 Ski Nautique
Duane in Indy
Alex , sorry for the delay. SPTT switch is an ON/ON/ON switch that you can leave one of the ON positions disconnected. I leave the down position disconnected that way at a glance I know that all switches down are OFF. Ebay has at least one toggle type. Carling #2GE54 ON/ON/ON |
1978 Mustang (modified) |
forvicjr
Gold Member Joined: August-24-2012 Location: sc Status: Offline Points: 692 |
I have two pumps, one 500gph and one 800gph. Yes im paranoid, my boat is foamless. Both will activate via the switch. One has a float switch connected to constant power which overides the the switch and will activate when bilge water is present.
“Tact is the ability to step on a man's toes without messing up the shine on his shoes.” ― Harry S. Truman
74Wind
Should have been more descriptive I guess. while at it thought I might compare all the spaghetti under dash to an overall schematic if there is such a thing for my year/model. Never mind......
1974 Southwind 18
1975 Century Mark II |
Alex47
Senior Member Joined: November-11-2010 Location: Tarzana Status: Offline Points: 136 |
Thanks for the input. I'm leaning toward the float switch option.
I like the 3 position switch idea. Can you post a link to where I can find that switch? |
Duane in Indy
Original design was to run two pumps. No diode needed for single pump |
Jeff,
Get the VOM out or as others have suggested get a mechanic. Are there 2 or 3 wires coming out of your bilge pump? |
desertskier
Duane in Indy
I wanted all my switches to be OFF in down position. Finding a On/On/Off switch is hard to find. Only a SPTT switch will work (that I know of) |
So if your switch s on/off/on and you could have wired it just like boats with 2 separate switches? Are there not on/on/off switches available? Am I out to lunch?
Duane in Indy
On my boat I only wanted one switch to do auto and manual both. I wanted the down position to be off rather than a center off switch. Your way would work also if you wanted two switches. |
^^agreed
If you need a schematic to troubleshoot a bilge pump, you may want to consider bringing it to a mechanic. |
C-Bass
No |
What do you need a schematic for? Pump power goes through float (switch) then dash (switch). Activate the dash switch and it'll pump when float raises. Some pumps have a direct on power wire too, like my 88. It has auto and manual switches at the dash. For boats with only 1 dash switch I'd wire it like above, auto mode only. It's been a while since I futzed with a bilge pump but am I over simplifying this?
Duane in Indy
Am on road to a drag race in Texas and can't send pics from iPad. Back in town Tuesday and would be able to forward then Duane |
74Wind
My dash switch does not operate which I need to troubleshoot. Pump works fine, float works, and if I wanna manually activate it i just lift the float. Any wiring schematics on external float switch type assembly would be appreciated.
1974 Southwind 18
Duane in Indy
I am using a pump with the float switch you show. I have a toggle switch that is three position. UP is On manual, Center is On float, Down is Off. Simple diode in line and use
SPTT switch. Really easy, I can post schematic if interested |
phatsat67
The auto pumps are pretty cool but you don't want to leave it more than a couple weeks or if the battery isn't questionable. They cycle no matter what where as a float switch will only run when there is water present. So long term storage would be better with the float switch.
AAM196
I wouldn't leave a boat in water w/o one.
I cannot speak about the newer boats but my 95 has the factory provided Water Witch system. Seems to work but I don't leave it in overnight
JPASS
We added a float switch to ours and it worked great. Never had an issue with it sticking.
'92 Correctcraft Ski Nautique
Alex47
I'm planning on renting a boat slip for 1-2 months in the summer and keeping the boat in the water. What are your opinions on automatic bilge pumps and float switches? My existing pump is activated by a switch on the dash manually turning it on/off and works fine.
1) Should I just add a float switch to my existing pump? I've read several opinions/reviews about float switches getting stuck in the down position (thus not activating the pump when needed) or getting stuck in the up position (killing the battery and/or killing the pump). Does anyone have a recommendation for a decent reliable float switch? OR 2) Should I buy a new automatic bilge pump? There are 2 variations; one that has a float switch and comes with the down falls described above, and one that is on a timer and senses for water by cycling every 3 minutes. Opinions? Product recommendations? |
