WOT Martinique w/new prop - rpm? |
mandovoodoo
Newbie Joined: April-16-2006 Location: United States Status: Offline Points: 22 |
Posted: June-12-2006 at 10:41am |
Got a cheapie ebay 13x13 on my Martinique, mainly so I could get the 13x12 that was dinged into the shop. Cruises wonderfully and very smooth now, but WOT is only 4000 rpm. This seems too low to me. The 13x12 when only slightly dinged (prior to hitting the submerged lawn chair) would give 4200 rpm, which seemed more like it. I was sort of thinking based on the obscure reading available that 4400 rpm would be optimum with a light load and WOT. Engine is running essentially perfectly.
351 PCM, 86 Martinique, no ballast tanks or anything, very clean bottom at this point. Thanks for any suggestions. Maybe a 13 x 12 ACME would be better than spending the $ on my old prop, and I could put the 13x13 back on eBay. |
www.mandovoodoo.com
mandolin research 1986 Martinique, TN |
Munday
Gold Member Joined: August-17-2004 Location: United States Status: Offline Points: 538 |
Glad it smoothed out for ya,theres alot of difference in props even of the same size.The amount of cup plays a big role,since I have no rookie drivers I like a little more rpm around 4800,did you notice alot of extra lift with the 13x13?I've had props that seemed to lift the rear of the boat usually when I didn't have the hp to pull them.Also a good prop shop can cut the 13x13 down for you so you'll have a good spare.
Good luck Munday |
mandovoodoo
This prop has a bit of cup. I wouldn't mind more rpm. I don't know much about these boats, but I can drive things well in general. The rear lift was obvious.
By cutting down, does that mean reducing in diameter? Now I'm wondering whether to simply get a a 13x12 or 13 x 11.5 Acme. Difficult. I don't know this prop game very well. Thanks! |
www.mandovoodoo.com
Martinique87
Groupie Joined: November-29-2005 Location: United States Status: Offline Points: 75 |
I have a acme 542 on my 87 Martinique (351) and its WOT is right at 4400.
Tim |
mandovoodoo
I think we'll go ahead and get a fancy new ACME. May well pay for itself in gas over the next 200 years!
www.mandovoodoo.com
