  New Posts New Posts RSS Feed - Driveshaft failure and lost prop... need to replac
gsmith795 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsmith795 Quote  Post ReplyReply Direct Link To This Post Topic: Driveshaft failure and lost prop... need to replac
    Posted: July-17-2016 at 4:08pm
So today my driveshaft snapped and my prop sunk to the bottom of the lake. It happened as my dad was opening the throttle during my attempted slalom run this morning. Just as I started planing off there was a loud thud, the boat lost power and the engine started racing. After being towed back to shore I swam underneath to take a look and discovered that it sheared off right where the driveshaft enters the strut, and the prop is somewhere in the weeds. Has anyone ever had this happen to them (or heard of this happening)?
Regardless of why it happened, I now need a new driveshaft and prop. I have a 1986 Ski Nautique 2001. Can anyone tell me where I might be able to order a replacement of each component? Thanks
Blamey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blamey Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 4:35pm
Delta Propeller is a site sponsor and has some of the best prices for Nautique propellers. They should also be able to recommend a good replacement prop. USE they code DP5CCF08 for 5% off.
Plannet Nautique or SkiDim will have shafts. Use PND code for 10℅ off at Plannet Nautique.
Most will recommend the A.R.E. double taper shaft.
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 4:42pm
I suspect your alignment was off causing stress on the prop shaft that eventually broke it.
If the water is not deep and you have a good idea where the prop is it might be worth getting a diver to recover the prop.   I found a wedding ring for a friend in the lake we ski once. If you find it soon you can usually see the color from the stainless shaft but if the sit there a while they will take on the mud bottom color and be much harder to find.
At least your boat is OK.
I second the tip below to use an ARE shaft. They are much easier to install and replace if ever necessary.   Do some reading on proper shaft alignment or you will have this happen again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 5:54pm
Tim,
Did the shaft break just aft of the strut like this?
If so, a break there is from a prop strike bending the shaft and then the constant vibration from the bend flexing the shaft.
A break from misalignment is always just aft of the trans coupling since that's where the stress is. Same principle with the constant flexing of the shaft.
Yes on the ARE shaft.
Silver15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Silver15 Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 6:56pm
I believe I have a shaft for this boat... I don't have a prop. PM me if interested in shaft.
2000 Air/Sport
1978 T16
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsmith795 Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 7:14pm
Pete- the shaft actually snapped just inside the strut housing, about an inch further up the shaft from where it snapped in your picture. I guess a prop strike is the culprit here. I can still easily turn the shaft by hand so I hope this means that the alignment is ok (not that it matters since I'll be replacing the driveshaft soon).
Jake- I will do some research and PM once I learn about more about the options.
Thanks all for the info and the recommendations!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsmith795 Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 7:27pm
PlanetNautique looks like a forum, where would I got to purchase parts?
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 7:36pm
You want to go to:
www.nautiqueparts.com
or
www.skidim.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 7:45pm
Tim,
Skidim will have a good price on the ARE shaft. Also, the other benefit with the ARE system is it's real close to the cost of a single taper shaft!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 7:48pm
Originally posted by gsmith795 gsmith795 wrote:
Pete- the shaft actually snapped just inside the strut housing, about an inch further up the shaft from where it snapped in your picture. I guess a prop strike is the culprit here.!
Yup, at one time the prop was hit bending the shaft. Even though you say the shaft turns easily, do check the strut to see if it's bent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 7:51pm
Tim,
I forgot to mention, this is a good time to replace the cutlass bearing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsmith795 Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 8:02pm
Tim,
Should I buy a new cutlass bearing from wherever I buy the new driveshaft?
Also, Is there a way to figure out what size driveshaft I need without getting into the boat and measuring the current one? I'm at home now and I won't be back up at the lake til next weekend. I'd love to install the new components when I'm back up there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsmith795 Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 8:04pm
Tim,
Just curious, what's the difference between a single taper and double taper shaft? Pros/cons of each? Sounds like double taper is much easier to install.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 8:36pm
Tim,
As far as I'm concerned, all the pros go to the ARE and all the cons go to the old single taper. The single taper is a PITA R&R due to the coupling on the trans is a heat shrink interference fit. That means the coupling must be pressed off the shaft. Then, for the install the coupling needs to be heated to expand the bore to get it on the shaft before it cools. The ARE shaft has a taper at the coupling end with a matching coupling and goes on similar to a prop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blamey Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2016 at 8:37pm
Sorry, PND is the Nautique Parts discount code.
96 Super Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2016 at 2:22am
This forum convinced me to install the ARE shaft two years ago when I needed a shaft.
It was very good time saving advice, it did cost a little more but the install was so easy and that is worth a lot of money. Time is important when the season is on.
The old prop shaft can be replaced and people did it that way for years but you might find out your trans coupler is already worn out which puts the price even between the upgrade and the old style. Hope you get it fixed again soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsmith795 Quote  Post ReplyReply Direct Link To This Post Posted: July-18-2016 at 2:31pm
I ordered the ACME 540 prop from Delta (using code "DP5CCF08") and the A.R.E. 1"x54" shaft with a new set of strut bearings from Skidim (using code "USA").
Paid extra for 3 day shipping so I'm hoping to get the parts by Friday and do the install this Saturday.
Thanks everyone for the help and the coupon codes!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsmith795 Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 10:49am
Had partial success with the install this weekend. The driveshaft and new cutlass bearing arrived from Skidim on Thursday but the prop never showed up (despite the fact that I paid for three day shipping on Monday morning).
We did the driveshaft install, running into a few snags along the way. First issue was that we couldn't get the driveshaft out of the old coupler. We took a blowtorch to the coupler but that didn't work, so we ended up cutting through the old driveshaft with a dremmel. Second issue was the driveshaft was directly in line with the rudder, so we had to remove the rudder to get the old driveshaft out (of course the rudder was then hitting the trailer so we had to jack up the boat a couple feet to get the rudder out. Third and most painful issue was getting the old cutlass bearing out of the strut, which involved cutting through it with a hack saw and then slowly prying it out with a hammer and a chisel. The new bearing slid right in after 30 minutes in the freezer and the new driveshaft and couple bolted right up.
My buddy had a spare prop for his mastercraft that he said I could use until my Acme 540 showed up, but after installing and dropping the boat in the water we quickly realized that it was left hand drive and I needed a right hand drive. It's quite a strange sensation putting the boat in reverse and having it slowly start to lurch forward.... i'll be swapping in the new prop once it shows up.
Very disappointed with Delta Propeller!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 11:21am
Tim,
Sorry no one including myself mentioned cutting the old shaft off. When a replacement is being installed, it sure is easier that fighting the old coupling with it's heat shrink interference fit   Heating the coupling when it's on the shaft doesn't work since both it and the shaft expand at the same time.. It has been mentioned in other treads on an ARE install. Also, with getting the old cutlass out, you did it the correct way. Did you do anything to see if the strut was bent? How did your alignment go?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsmith795 Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 11:33am
Tim,
I guess I should have done a bit more reading on the topic before tackling the install. After we pulled the new shaft out of the box and realized it came with a new coupler we were kicking ourselves for not just cutting the old shaft right away. We thought maybe we'd need to keep the old coupler.
We didn't do anything to check if the strut was bent, but the new shaft slid right in, the coupler bolted right up to the transmission with no issues, and it turns without much effort. What would be the process for checking strut alignment?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 11:38am
Tim,
Check out the FAQ thread in the maintenance section. It has links to many topics of interest. The first link happens to be on alignment. If you can't find what you are looking for in the FAQ's, we're always around to ask.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 11:55am
You ordered a popular prop it's possible they were out of stock. For some reason when they have to order one from Acme they have it sent to them rather than having it shipped directly to you. I ordered a odd ball size prop last winter and as you was disappointed in the amount of time it took too,but they were cheaper and no guarantee that others at full price have them in stock either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsmith795 Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 12:21pm
Tim,
I will definitely take a look at the FAQ's, thanks for sharing!
Yes that's a good point, I guess I never considered that it may not be in stock. Their website doesn't indicate whether a part is in stock and neither does the confirmation email they send after an order is placed. Hopefully the new prop arrives before I head back up to the lake in two weeks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 12:31pm
It might be worth your time just to give them a call and talk to someone to check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsmith795 Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 5:37pm
Turns out they are updating their computer systems and my order slipped through the cracks. It should have gone to the customer service desk and been marked as 'incomplete' so that someone could manually fulfill the order, but instead it bypassed the desk and was marked as complete so they had no idea. They are refunding my three day shipping and they are sending it via UPS overnight today. It's a bummer I didn't get to install this past weekend but I'm glad they are making it right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 5:42pm
Best advice ever for most problems, if you can't do it in person
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 5:49pm
When I bought my 95 it had a vibration in it on the first test drive. I tried a second prop I had and it had the exact same vibration. I found our the prior owner had hit the prop hard and only fixed the prop. They ran it like that and the alignment issue wore out the cutlass bearing and wore out the coupler at the shaft to tranny connection. The prop shaft was bent and the prop strut was bent. Advice on this forum got it working perfectly again but just replacing the shaft was only a partial fix. The shaft alignment and strut alignment is what got mine working smooth as silk.   If you did not use feeler gauges to verify your alignment it was not done.   If you did and it is good you are in good shape. The hard work is done, make sure the important work is done with proper alignment check.
Good Luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2016 at 6:37pm
Must be a age thing I don't trust those newfangled computers,they'll never amount to anything once the novelty wears off
I don't have any notes on the transaction anymore but if I remember right I had a similar problem last February with them and because it was out of stock took about 3 weeks
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2016 at 12:13am
I got mine in a couple of days with no extra shipping cost but I called them because I wanted to change the cup on mine.
