Running WAY too rich. |
KooK
Senior Member Joined: February-10-2014 Location: Iowa Status: Offline Points: 143 |
Posted: July-28-2016 at 11:34pm |
So I just did a leakdown on my 79 Mustang 17 (302 V4) and it came back that all of my cylinders are between 60-70% @ 100psi with 30-40% basically just getting past the rings. When I took my plugs out they were blacker than the night sky, so obviously I have an over-fueling issue. I was wondering if somebody could tell me if this is the correct carb for my boat, then we'll go from there.
Holley 4bbl |
KooK
Thinking about it, I did have to idle in for quite some time the last time I came in... Probably a bad test of plugs unless I shut it off at WOT. Either way, kinda low leakdown.
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2957 |
When was your carb last re-built? Call Vince at www.skidim.com and he can get you the proper carb re-build kit. In your top picture you captured the the carb numbers stamped on the air horn. Before replacing the carb, I would try this option.
JQ |
Duane in Indy
Per the Holley manual:
List 7159 is a model #4160 450cfm rebuild kit #703-33 Google "d4jl f" several sites show that carb for a 302 |
1978 Mustang (modified) |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
Just to add a little to what Duane said 302's came with a 450 CFM Holley and my Holley manual agrees with his. Also if you rebuild it, do yourself a favor and get some new bowl screws for the front float bowl cause those style are just terrible for a lack of any better words. You'll see why when you take them out The secondary bowl screws look like they've been replaced (they appear to be a hex head) but the front look original The front are longer than the rear so make sure you get the right ones. And 450 CFM is plenty for a stock 302 |
