  New Posts New Posts RSS Feed - 255 Pretty Ponies
255 Pretty Ponies
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Topic: 255 Pretty Ponies
    Posted: June-23-2006 at 10:08am
Just thought I'd post these pics here.
(lot easier than changing Diaries)
1974 Thermo Electron
http://i54.photobucket.com/albums/g96/DrCC-74/255prettyponies-01.jpg
http://i54.photobucket.com/albums/g96/DrCC-74/255prettyponies-02.jpg
Transom pic
http://i54.photobucket.com/albums/g96/DrCC-74/74-transom-01.jpg
AT
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2006 at 10:31am
picture #1
Picture #2
Looks nice.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2006 at 10:41am
different place for mounting the tranny cooler
Looks clean
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2006 at 9:44pm
David; Thanks for posting the link......makes it easy for us compu challenged guys.
john
"Loud pipes save lives"
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2006 at 10:29pm
jbear,    Doh!
David,    How? splain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2006 at 11:12pm
Doc: Don't take my comment personal, just meant to thank David, I can't do it either!
john
PS: Nice lookin' motor tho.
joed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joed Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2006 at 8:07am
Dr CC
You can make an active link for your pics by following the example below.
URL=http://www.FullWebAddressHere.com]Your Link t*tle Here [/URL
You just need to add an open bracket [ at the beginning of the line (in front of URL) and a close bracket ] at the end of the line (after the /URL). I had to leave these out so the code would show up.
Then you just pop in the full web address of your pic after the *URL=* and the name you want for the link after the web address.
So you have...
*open bracket* URL= full web address *close bracket* Link t*tle *open bracket*/URL*close bracket*
So your first link would be...
URL=http://i54.photobucket.com/albums/g96/DrCC-74/74-transom-01.jpg ]Transom Picture [/URL
again... you have to add the [ at the beginning and ] at the end.
Here is what the link will look like...
Transom Picture
If you click on Forum Codes below the post message area it will give you examples.
Hope that helps.
Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2006 at 9:48am
You can also put pictures right in the post.
Good looking boat, Doc!
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2006 at 6:26pm
Thanks Guys!!!
jbear,   That was me saying Doh! ya know, like Homer Simson. I might be related.
Looking for Paul-67nautique312!!!   Been trying to E-mail you trailer pics. They keep bouncing back.
Thanks again!!!   I'll try it.        AT
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2006 at 9:24am
DrCC:
Posting links (or pictures) is very easy. Take a look at the icon buttons just above the box you use to compose your message post. See the button with the globe and a chain link? Push that button and a dialog box appears. Simply type in the name of the link text, then hit enter. Now, another box asks for the link (http//....). Simply cut and paste the link into this box and hit enter. Bingo, the proper format shows up in the message box. Continue typing all you want and then when you post the message, the link is highlighted blue. Pictures work basically the same way by using the "picture" button. Good luck.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2006 at 11:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2006 at 1:35am
175 is on the low side for a v-8
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2006 at 7:14pm
79,   what do you mean, "low side"? Horse power?
175 is an OMC rating. It's a 2 barrel.
