1st Generation Ski Nautique Roster |
Post Reply | Page 123 5> |
Author | |||
skutsch
Posted: August-09-2016 at 12:29pm |
Art always wanted to start a Thread to track the owners of 1st Generation Ski Nautiques. So hear you go Art. We should let Alan be the first to post here as he is the owner of Ski Nautique Number 1.
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5771 |
Ok Steve Thanks. Maybe post the hull numbers too, be interesting to see where the oldest CorrectCraft Ski Nautique is
#1 GLASS CRAFT Ski Nautique., Illinois Contact: 81Nautique, Alan Arrighi |
skutsch
SN1330 1964 Correct Craft Ski Nautique. Iowa Contact: skutsch, Steve Kutsch (for owner Roger)
Ford interceptor 312. Seat configuration: Driver, Side Facing Observer& Rear Facing Officials Seat (Port side next to dog house), Teal Deck, white hull with teal boot stripe. Plywood Dog House, Optional Ski-Matic Electric Ski Rope Retreival Sytem. Original Trailer |
62 wood
Had to chime in.. (also to get notices of posts :) 1st Gen Roster...Great idea!
A first Gen SN is on my "looooong range" bucket list. LOL |
C-Bass
1967 - Power Blue, split windshield, 318 Chrysler.
In the midst of a slow going restoration of stringers, floor, all interior and gelcoat. Here is a picture from several years ago prior to going under the knife. |
ArtCozier
On behalf of Correct Craft, registering the 1961 Ski Nautique that lives in the reception lobby at the factory. It goes to the Masters Waterski & Wakeboard Tournament at Callaway Gardens each year, leads the Opening Ceremony boat parade and bears the Flag for the National Anthem before the finals, I also frequently bring it to CCF events.
Unfortunately, the hull ID number was lost when the boat was re-stringered in 1986. We know that it was one of the first few built by Correct Craft after acquiring the molds from Leo Bentz. It could have been the first one, but we can't claim that without evidence. It's a white hull with red deck, as were most of the boats that we built for Cypress Gardens. The engine is either a 292 or a 312 Interceptor, we don't know for sure which it is. |
"Art"
Art, Has the engine ever been rebuilt? If not, I'd say it's the 292 or even a 272? If you get a chance, look for the engine model number which will confirm the CI. It will be on the cam shaft cover where the mechanical tach output drive is located. BTW, does it have a mechanical or electric tach? |
Chevy350
Gold Member Joined: June-24-2013 Location: Illinois Status: Offline Points: 721 |
There's two first Gen on my lake.
#1 which is my uncles. He is technically 3rd owner but I say 2nd because my family was the 2nd but we never did anything to it. We know the whole history of it and it's been either in family, or very close to family it's whole life. 1969 Ski Nautique originally had a 318, but now has a 440 (sorry pete, I tried to tell him keep it original) Red hull with ivory deck. #2 Some guy on our lake has a 1966-1969 (don't know exact year) Sea foam green that seems all original. His dad was the original owner and it was passed on to him. I've been trying to talk my dad into buying it and restoring it. |
1972 Mustang
And this lake is called?
Chevy350
Lake of the Woods. It's between Bremen Indiana and Plymouth Indiana. |
1972 Mustang
Air206
Old skier
Newbie Joined: April-24-2013 Location: Iowa Status: Offline Points: 39 |
This is my 1964 Ski Nautique hull number SN 1378. Second owner. Yes I did do some modifications,
ArtCozier
Pete, the original front engine cover, which is where Eaton stamped the engine data, long ago went to Corrosion Heaven and was replaced with a service part. Those covers are known for corroding through at the 90-degree turn where the water enters the block. And when they corrode through, the water goes directly into the oil.
I don't remember enough about the rebuild to be sure, but I know that we replaced the block. Whether it was an empty block or a short block, I don'[t remember. 292s and 312s were machined from the same castings, so the casting numbers only mean that it is one or the other. The cranks are different, and one way to tell without going inside the engine is to look on the flywheel flange on the crank. A 312 crank will have a round indentation about 5/16" in diameter on the flange. And I'm not about to pull off the trannie, bellhousing, and flywheel to find out! |
"Art"
ArtCozier
"Art"
ArtCozier
The engine has the connection on the cover for a mechanical tach, but there is an electric tach in the boat. I don't think there ever has been a Ski Nautique built by CC that had a mechanical tach in it. I think the Graymarines were the last engines we set with mechanical tachs. |
"Art"
Old skier
Looks like a center deck boat. Do you know the hull number? I am with Art, don't part it out. How are the stringers?
And the Hercules tagged as Correct Craft engines but marinized by Chris. |
Adding my '67 to the list, will have to check the hull number. Originally had a LA/LM 318 and a wood motorbox. TBD what goes back in it... This boat is on my long term list.
ArtCozier
The only thing I can see missing is a pair of "polished stainless CC logos! : )
"Art"
jbear
calender shot Steve...nice shot of Alan's/Gene's beautiful '81 in the background. john |
skutsch
Never made it, got lost on the cutting room floor. MY pictures are not MoreFoot or Frankenotter quality. Don't forget Pete's Atom to the left of Alan's/GEne's. I like to think of it as Grampa (Atom), Dad (Gen 1) and Son... |
ForestB
Newbie Joined: August-13-2016 Location: Southafrica Status: Offline Points: 19 |
Hi Guys just brought another project boat been told its a nautique can anyone give some info ?
ArtCozier
It looks like a 1970;s Ski Nautique, but I can't tell for sure. Is the dashboard area inside the windshield gelcoated in black? The wing vents in the windshield date the windshield, but I don't recall the year that they were put in. If it's a 1972 or earlier, there should be an aluminum plate in front of the throttle control with a model and number stamped into it, like SN 0000. If it's '73 or later, there will be a number engraved in the upper starboard side of the transom that begins with CTC followed by nine more characters. The engine definitely doesn't look original.
"Art"
ForestB
Thanks alot will have a look later , the engine is a 383 Chrysler apparently they were not originally marine engines but guys like to convert them heres another pic
Definitely a 1st gen SN but it's been highly, umm, modified. I don't see much original hardware left on it. Doesn't look to be a period correct Chrysler marinization, I'm guessing that's not original either.
ArtCozier
I haven't been able to decide whether I'm seeing wood spray rails on the forward chines, or if I'm seeing shadows in the photos. Wooden rails mean 1969 or earlier. Also can't tell whether the "rail" that ran around the perimeter of the foredeck on the Gen Ones is there or not. In the third photo (the one with the price still written on the w/s) it looks as though it's there, but the other photos, no.
Forest, how about some photos of the items we have mentioned when you have time. The interior, the foredeck, chines forward, etc. The engine and the pylon are definitely not original equipment, but nothing negative about that. |
"Art"
ForestB
basically what is left in the boat is the engine , propeller , gear box ,steering wheel and throttle control , I can confirm the splashgaurds are wooden I will send some more pics as soon as i can , The marinization is definitely a home job but not badly done at all . I am also busy restoring a 67 with a Chrysler 318 250hp the only part not original on that is the windscreen have the original carpets too but need to be replaced
Old skier
Looking at the pictures, it looks like a 1969 of prior Ski Nautique. I, like Art, would like to see a picture of the foredeck to be sure. The windshield is not correct, and there are things missing, like the front and rear left rings for the boat. If there is a hull ID number still attached it would be in the engine compartment, SN####. Looks like a project.
cbr1000dude
Senior Member Joined: August-23-2011 Status: Offline Points: 330 |
Like this on my 1967 SN |
cbr1000dude
