'97 Skeg Removal |
86ER
Groupie Joined: November-10-2015 Location: Florida Status: Offline Points: 63 |
Posted: October-19-2016 at 11:27pm |
Can you remove a skeg without having to access the nuts inside the hull? For instance, did Correct Craft use nut plates for the skegs so you don't have to worry about the nuts inside the hull spinning or moving out of place when unscrewing the bolts?
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21108 |
No plates, no nuts on that era boat. Just screws. Cc smartened up and decided a fin strike shouldn't result in massive holes in the hull.
86ER
Even better. Thanks for the info and quick response.
