Ford Dearbomatic seals needed |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 885 |
Posted: March-04-2017 at 10:43pm |
Anyone have any source for Ford Dearbomatic gaskets and seals?
Mine leaks into the bell housing from the input seal. Any help greatly appreciated. Thanks. |
Thanks(1)
Brian,
There should be a number on the seal. Any power transmission distributor will have it or be able to get it. If there isn't a number, dimensions and the type will work. I think Kaman Industrial is out west by you. For gaskets, I suggest cutting them yourself from sheet. |
MourningWood
Thanks Pete.
I'll pull it apart and have a look. Rear main leaking a couple drops per hour too. Ugh!!!! |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5765 |
Is this that beautiful 312 you put together for the X55? Shame to have to pull that apart.
MourningWood
Thanks...yes, I know it kills me. It runs so beautifully too. This boat is quick.
Over last winter it got a new, correct bottom keel, and frames. Frank and Brian Casey of North Lake Tahoe did a superb job. As you may know, the engine is right-hand rotation and I could not find a correct, direction-specific rear main seal, so tried the rope seal. I lost round 1. I have more paint, and am confident I can prevail. Will keep you posted. |
I'd be real surprised if a RR seal was ever made for those engines. My early '70 302 block used a rope seal. I removed the pin and installed a 2 piece seal which leaked because of the knurling on the crank was for a left handed engine. In the end I used another rope seal which has worked fine
81nautique
Pictures are long over due!!! |
MourningWood
Well, since I asked the question, thought I'd offer the answer. Hopefully helps someone else
down the road. Ford Dearbomatic trans seals: Input (front) seal: p/n 15222SC Nitrile oil seal Output (rear) seal: p/n 17253SC Nitrile oil seal Bought from "The O-Ring Store, LLC", Lewiston, ID 208-413-6377 |
