  New Posts New Posts RSS Feed - Strut Set Screws Stuck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Topic: Strut Set Screws Stuck
    Posted: April-01-2017 at 2:31am
I can't get the damn set screws out of the strut. I may have to drill them out if the Easy-Out doesn't work.
Any suggestions for set screw replacement? I can't find anything on skidim or nautiqueparts. Are they brass or stainless steel? I've heard of some folks leaving them out completely.
Next question: Vesconite or standard brass/rubber bearings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2017 at 6:19am
Rob,
I'd use the set screws even if the new cutlass is a tight fit in the strut. They aren't anything special. Your local hardware store will have them in SS,
As far as going plastic or rubber, I'd say it's a 50 - 50 split with opinions. It's your call on which to use.
Frankenotter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2017 at 7:52am
I had to drill all 4 screws on two different struts. I used a drill that was about the diameter of the hex key. Then I used a good extractor to back them out with some kroil.
1999 Ski Nautique 196
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2017 at 11:37am
Update...
I tried an Easy-Out and one of the set screws came out. The second one was frozen solid. I was worried that the Easy-Out would break off and leave me with a bigger problem, so I drilled the screw out.
When I finally got the damn strut bearing out, I re-drilled both set screw holes and tapped them for a #10 fine thread. The local H-D had stainless steel set screws in #10 fine thread that were 3/16" long. Problem solved. I plan on blue Loctite to keep the new set screws in-place.
