  New Posts New Posts RSS Feed - Need more juice for stereo???
SMay81SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMay81SN Quote  Post ReplyReply Direct Link To This Post Topic: Need more juice for stereo???
    Posted: July-06-2006 at 12:11am
Since I was given advice (by J_I_H ) to repost my quest for help instead of posting on a "tired" thread here it is again.....
I don’t know where to start. Not an electrical guy. With our new 94 SN, it has a stock Alternator, I believe the stock stereo amp, a new CD player head unit and 4 stock speakers. I believe it(alternator or battery) are not putting out enough power. The ignition beaker needs to be on for anything to work first, if the blower or auto bilge is on then the stereo does not have enough power to turn on. If these things are turned off then it will work. Also while motor is running all things will work. Push the horn and stereo goes off, or the bilge comes on, stereo goes off.
Please let me know what I can do to eliminate this. I need help. I'm NOT trying to have a 500 watt stereo blaring while we are running but just trying to enjoy a few tunes while out on the lake…..I have 3 or 4 teenagers in the boat all the time so the stereo is a necessity.
Scott
Our 94 SN
great78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote great78 Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 1:08am
My 96 sport does the same thing. They dont have much in the way of a battery to begin with so I ass-ume that with the engine off and working off of battery only, the bilge has priorty if it gets a start signal. I dont think the alternator comes into play here on this as you mention that all work when engine is running. I'm looking at a second battery set up so a fused hot can be run direct to it and wont compete with the bilge etc.
SS-201 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS-201 Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 5:48am
The best way to have the amperage needed is simple,however the manufacture is too cheap or doesn't have a clue.
Coming from a truck, bus ,environment in order to have the power needed rather than to put put on a ridiculous alternator that in time will melt your battery..
You put two 6 volt batteries in series you will have 12 volts and double the amperage ex. 2 -6 volt 500 amp would give you 1000 amp and 12 volts. This will not over work your alternator and melt the batteries. You will have all the power needed end of problem.
SS 201
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 9:34am
Check and see if the amp is wired straight to the battery. If it is connected to the fuse block with everything else I would re-route it.
Tim D
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 9:49am
Tim D, he should put an in-line fuse in the line he runs from the amp to the battery right? What size wire should he run? #10?
Be sure to get marine grade wire. Do not use wire you get at the auto parts store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 9:58am
Yes, put an in-line fuse close to the battery and I would use multi strand 4 gauge wire.
Tim D
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 9:58am
the guage of wire will depend upon the amp, I use #8 on mine. Most newer amps have a fuse built into them so there is no need for a inline fuse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMay81SN Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 10:18am
I believe the amp is already wired directly to the battery and has a inline fuse. I remember looking at the extra wires connected to the battery and a large square fuse in the line. Boat is at lake house and hour away have to check next time I'm there. But wanted to have ideas of what I could do before I go. More ideas or suggestions are welcome
Scott
Our 94 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 10:47am
The voltage regulator could be going out in the alternator, you might want to have it tested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMay81SN Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 12:07pm
Thanks Chris...hey what have you done with the 81? Is it hanging on the wall in your friends bar yet? I would like to get a picture of it...since we loved the boat for 18 years...
Scott
Our 94 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 12:21pm
not yet it's sitting on a craddle in the barn right now.
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2006 at 9:47pm
    Sorry to butt in on this, but wanted to correct the statement. 2) 6V 500amp batteries in series will give you 12V at 500amps. The voltage doubles, but current stays the same.
    Scott, sounds like there is a issue. It almost sounds as though you are getting some serious voltage drop issues either with the wiring or a bad alternator. Its shutting down probably due to excessive low voltage. Make sure the ground goes direct to the batt as well and is not tied to the factory ground bus. A fully charged decent sized batt should run it OK with the engine off for a bit. Make sure its wired properly and not actually feeding by accident by the ignition instead of the line to the battery. Also, a inline fuse as close to the battery as possible like JIH said is needed to protect the wiring from burning the boat down if it were to short out. Good luck!!
                                    Jeff...
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS-201 Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 5:23am
Two 6 volt batteries in parallel will give you 6 volts and 500 amps. Two 6 volt batteries in series will give you 12 volts and 1000 amps. End of quote.
SS 201
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 6:41am
If it were that easy to quadruple power, we wouldn't have an energy problem.
River Rat to Mole
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 10:17am
I'll weigh in (don't know why...guess just bored today). I agree with GottaSki. Batteries wired in series will increase voltage, but capacity remains the same.
When the batteries are wired in parallel, you are doubling the capacity but the voltage remains the same. You cannot do both... it's an either or kind of thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 10:23am
So you guys are tell me that we screwed you when we designed the battery box for the EV1 and wired the batteries in series to increase amperage output to drive the propulsin system to get the land speed record...OHhhh... waite a minute..... the batteries where in stock configuration and we only added potting to the stator windings to handle the extra heat.
Or in other words you guys don't know what your talking about again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 10:36am
79...
Not sure where you are coming from on this, but I guess I can clarify my position and say that if you have amultiple battery bank (more than two) then you can indeed increase voltage AND capacity by doing a combination of wiring the batteries (or cells) in series and in parallel. Not on the same cell/battery, but some in series and some in parallel.
Just to make sure I am not all wet on this, I did some looking on the internet (and you know everything you read is accurate) to support my argument. Tell me again why I chimed in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 10:36am
I think you guys are mix-matching terms and you are not talking about the same thing.
Two 6 volt 500 Amp/hr batteries can be connected in series to give you 1000 amp/hours with 12 volt output. This is true. However, max amp output is still limited to the 500 amp rating.
Ya'll calm down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 10:44am
The batteries where all in series and it was not a compination of paralell and series, they where even stacked on top of each other and ever single one had their own heating element as well as several sensors within the craddle that they where mounted in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 10:45am
Here is what they teach you in all (except the top 5 ) engineering schools:
In a series circuit the current stays the same but the voltage is additive. In a parallel circuit the voltage stays the same but the current is additive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 10:48am
I just don't know why anyone would want to series 6 volt batteries to increase capacity. Why not parallel two 12 volt batteries. This is what is normally done. In fact, with two parallel 12 volt batteries a disconnect switch can be added to disconnect your engine starting battery from your stereo when setting at the dock so you don't discharge your "main" battery. By doing this you can use a smaller 12 volt "motorcycle" type battery for your second "stereo power" battery. Switch in the smaller battery while running to recharge it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 10:57am
J_I_H:
Running two 6-volt batteries in series will only increase the voltage to 12-volts, it will NOT increase the capacity beyond the rating of the individual battery. Now, I agree the smart thing to do is wire two 12-volt batteries in parallel to double the capacity/amperage. This will allow someone to run the stereo until a single battery would normally be exhausted (or significant voltage drop), and still have enought reserve to start the engine. But, that is risky and it makes most sense to me to use a switch to isolate the stereo battery as you suggest. If I was to add a battery for stereo use, it would be a deep cycle type battery that is isolated from the starting circuit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 11:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 11:34am
David, we disagree a little. Doubling the amount of chemical solution and doubling the plate area will double the charge capacity (amp/hr capacity). In series, the ampacity will be limited by the smallest link in the chain - which I know you know. The max amp output will not be increased, beyond the max rating of the battery. The capacity will double but the ampacity will remain unchanged. The voltage of course, will be doubled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 11:43am
However, I see no gain of having two 500 amp/hr 6 volt batteries over one 1000 amp/hr 12 volt battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 11:47am
I see an added danger of seriesing two 6 volt batteries: without adaquate line protection the batteries could easily be overloaded resulting in a hazardous event.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 12:11pm
J_I_H:
Argh! Are we speaking on the same subject or using the same terms? Let's try it this way: Take two identical 12 volt batteries. Now, put a theoretical load of maximum voltage on one of the batteries so that it will be exhausted in exactly one hour. Now wire the two batteries in series: maximum load, at 24 volts, will exhaust the batteries in one hour. Now wire the two batteries in parallel: maximum load, at 12 volts, will exhaust the batteries in two hours.
I agree with: "I see no gain of having two 500 amphr 6 volt...."
PS. Your diagram (parallel) looks good to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 2:25pm
David, I stand by my earlier statements.
This is probably best sutied for an electrical forum somewhere. Not really a CC topic.... Have a good weekend David!!!!
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 2:37pm
For what its worth...
The old school method of putting two 6volts in series actually came about because not so many years ago the only decent deep cycle batterys to be found were 6 volt batterys used in golf carts, so if you needed a reliable 12 Volt set up you put them in series. Nowadays you can get 12 volt deep cycles.. and two of them in parallel is a much better solution precisely because if one goes bad your still in business. Conventional wisdom has not necessarily caught up to the technology in some circles...
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2006 at 2:41pm
Agreed...you have a good weekend as well.
