11a rudder and rudder port |
clint351mx
Newbie Joined: August-17-2016 Location: seguin tx Status: Offline Points: 18 |
Posted: April-11-2017 at 1:22pm |
Im in need of a 11a rudder and port box. I purchased a 1980 18ft sn and the rudder is super hard to turn by hand, disassembled and is majorly bent. If you ha e one please pm me.
Clint,
Chances are high that it's just the rudder shaft that's bent so you may not need the rudder port. BTW, rudder shafts have been straightened. The fit between the port and rudder shaft is not that precise. |
clint351mx
The actual rudder part itself is bent a good bit as well, the shaft is bent backwards so when not inserted fully its fine, but as soon as i push it all the way in it has to be man handled to move at all. And there is visible wear on the shaft where it has been rubbing the interior of the rudder port. I havent even gotten to take the boat out yet, this was all done by previous owner. Im just trying to get it safe before i take it out. Just had the stringers and floors redone. Boat only has 85 hrs, but sat uncovered under a leaking barn. Im guessing it was put there after the rudder incident happend. The motor was replaced at 75 hours by previous owner who didnt winterize and cracked the block due to freezing. So the motor only has a handful of hours....only reason i couldnt pass up the deal. If anybody could help me put id appreciate it.
Clint,
What does the visible wear measure compared the unworn ID.? As mentioned, the fit can be pretty sloppy. How about some picture of the boat? We'd love to see what you're working on. |
clint351mx
I will have to post pics later, but the wear is visible gouges, like deep scratches, not like it had been worn over time, but like they hit something and had to muscle it back to the dock causing some big gouges. I couldnt even turn the rudder using the steering wheel, i thought because of it sitting so long that the steering cable had gone bad, but after disconnecting the rudder, the steering wheel turns fine. I the went to remove the rudder and after removing all hardware and couplers, i figured it would just fall off.... that wasnt the case, i had to work it back and forth with a ton of lube to get it out of the rudder port. Thats when i noticed the shaft was bent.
clint351mx
clint351mx
clint351mx
clint351mx
Clint,
The bent blade is an easy straightening. Seek out a prop shop or a machine shop that may be interested in straightening the rudder shaft (and blade). I feel it can be fixed. Once the shaft is straight, I'll say the port will be fine. Take the port with you so they can use it as a guide. The rudder doesn't need to be perfect. Thanks for the pictures. What are you plans for the boat? |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10649 |
Did the previous owner tell you what brand of marinization that engine is? The engine sure looks like it is an Indmar marinized 351w going by the raw water pump being crankshaft mounted and the shape/design of the thermostat housing, alternator location and a few other small details. The exhaust manifolds look like they are from Barr Marine All this will lead to somebody asking that big Correct Craft question of "which way does it rotate?" If you don't know, look at the distributor cap and working your way around it Counter Clockwise you should have either 1 3 7 2 6 5 4 8 if it's normal automotive rotation or if it's reverse rotation it will be 1 8 4 5 6 2 7 3. Make sure you go counter clockwise. Only reason I mention this is because it's looking pretty obvious that it's a newer replacement engine and manifolds and it'll be good for you to know what you have there. |
Just saw your post in your other thread where I could read 351 Sport Pac on the flame arrestor cover.
That means it's a Marine Power Inc. marinization. Good engines |
I wondered that too and saw the Reverse Rotation decal on the valve cover
Good eyes Gary I saw the decal, just didn't know what it said till you pointed that out and I enlarged it and used a magnifying glass. So Clint.... your engine rotates the Correct Craft way. |
clint351mx
Good to know, the guy i got it from said he paid a pretty penny for it.
clint351mx
I was able to purchase a rudder on this forum for a way better price that nautique parts wanted, i need to lnow how much of the packing material i need to buy tho?
Hollywood
3 wraps of 3/16" will get the job done but I like having extra around.
5' for $28 at McMaster 9466K5 |
