Exhaust Manifold drain |
Author | |||
malcolm2
Senior Member Joined: June-13-2010 Location: Nashville Status: Offline Points: 235 |
Posted: April-14-2017 at 12:43pm |
During winterization I noticed that one of my manifold drains has badly rusted threads.
The PO had put a bushing and a petcock on, but I prefer to remove the plug (bushing) and get some of the rusty bits out. So here I am, spring is here and I would like to fix this mess. The bushing is brass and not hard enough to cut the rust, and now the 1st few threads of the bushing are flattening out. I was thinking about chasing the threads on the manifold, but don't want to spend an arm and a leg on a single use tool like a 3/4" pipe thread chaser. Any ideas? |
malcolm2
Well I should have known that I could find a cheap one online. With free shipping & Sunday Delivery too! Amazon 3/4" x 14tpi tap |
Clark,
You don't need a fancy or even new tap. You are just cleaning up existing threads and not really cutting new ones. I've had great results shopping ebay. I just got a 1&1/2" pipe tap for $6.00 and it was new! |
malcolm2
at lunch I went to the Home Depot and bought a pipe plug. No need for the petcock thingy, I only open it once a year and still need a pair of pliers to open it. So it is not tool-less now. If I like the way it all goes together, I'll go buy one for the other side.
malcolm2
The inexpensive pipe thread tap did the trick. I slowly did both sides and then bought a couple $2.00, 3/4" pipe plugs from Home Depot and they threaded right in. No more petcock for me. 3/4" pipe plug at Home Depot Having the right tool always make work easy. Should I consider some type of pipe dope on the threads? Something to slow down or eliminate the corrosion? |
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1114 |
Your link goes to a 1/2-14 tap. Isn't it a 3/4-14 for a 3/4 NPT plug?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10650 |
It's a 3/4-14 just like you said |
desertskier
Thanks. Mine need cleaning up and I didn't want to order the wrong one.
malcolm2
not sure how I got the link screwed up, but yes NPT 3/4" with 14 TPI. I'll see if I can fix the link.
Link is FIXED. |
quinner
I have always used teflon tape on all the plugs, they never leak and come off easily each fall. |
Clark,
Glad to hear you got the tap and chassed the threads fixing your problem but am disappointed you got rid of the stop cocks. You probably had the cheap radiator drain cocks that don't allow you to probe for sediment so it builds up at the manifold low point. I have these on all my boats, have recommended them to members who have installed them and are very happy. They have a removable stem and are available up to 3/8" pipe size so there's plenty of room to get the crud out of the cooling passages. No threads to worry about anymore and no tools needed. |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2842 |
+1 Got 'em at McMaster-Carr. |
As great as they are, they seem irrelevant on the topic of 3/4" exh manifold drains... since 3/8" is the largest offered?
I guess you have never heard of a 3/8 x 3/4 pipe bushing! |
Thanks(1)
Soitenly!
Apparently you've never seen the size of the scale that can come out of a cast iron manifold! Sometimes you need all of that 3/4" hole to probe effectively. 3/8" ain't gonna cut it. Might not even fit with the 3" Ford or BBC risers anyways... space is tight. Sounds back yard hack to me! |
malcolm2
Mine had nice 3/4 to 3/8 brass bushings then the petcock as pictured above, so I think they were decent quality.
But I found that even if I un thread the petcock the water flow was very slow, so I removed the big bushing and found a large amount of rusty crud. The bushing kinda acted as a dam so the material built up. That being said, I figured, $2.70 for a 3/4" pipe plug was worth it. If anyone wants 2 3/8" petcocks, you pay the shipping and I'll send them to ya. The 3/4 bushings will be included, but the threads are boogered up a bit. I'll add a picture here if anyone wants them. I wondered if the brass-to-steel petcock set up did that dis-similar metals thing and increased the corrosion at the opening. Anyway, I might add some steam rated pipe dope and go to the lake! |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Online Points: 5767 |
Those petcocks are great for block drains but cast iron manifolds shed material the size of corn flakes and they ain't coming out of that little hole. If you're someone who skis late into the season and needs to drain after every day then they will suffice but they still need to be pulled once a year to get the crap out.
Gotta say I agree with Tim 100% on this. Maybe if you live in a different rust free world necking it down with a bushing and using a petcock would work otherwise it's just plain "not to smart" Like you said Tim, plenty of scale to get out of there. Edit after seeing Alan's post above mine, good analogy to the corn flakes Alan |
SNobsessed
I just tighten the pipe plugs slightly past finger tight. They don't leak & come loose easily in the fall.
Me Too |
mmasariu
Newbie Joined: April-22-2015 Location: Indiana Status: Offline Points: 39 |
Put these on mine, along with a little copper anti-seize.
Anderson Metals Brass Pipe Fitting, Cored Hex Head Plug, 3/4" Male Pipe https://www.amazon.com/dp/B006PKKVNK/ref=cm_sw_r_cp_api_QA.9ybMV0GHY0Anderson Metals Brass Pipe https://www.amazon.com/dp/B006PKKVNK/ref=cm_sw_r_cp_api_QA.9ybMV0GHY0 |
Matt Masariu
Speedway, Indiana 1987 Dominique |
desertskier
Thanks Pete. Damn it, I forgot about the j-tubes and only ordered 4 for the blocks. Oh well, another 8 bucks shipping. I have to agree that these baby's aren't going to pass many cornflakes. I think I'll stick to plugs in the exhaust. |
