Stringer rebuild 1987 Ski Nautique 2001 |
Post Reply | Page <12 |
Ken Correct, those USCG rules are just made up by idiots who really just want to make things difficult and aren't even thinking about safety! Lee, you are forgetting an important aspect of a mechanical fuel pump. That it's capable of pumping way more fuel than is needed by the engine so, even with a seal or diaphragm problem, the carb is getting plenty of gas. |
I dunno - if it starts to fail and is both running lean (hot) and with thinned out oil from the fuel in the oil one mistimed barefoot run could be your last on that motor. Particularly if the guy familiar with the boat is behind it and not driving it. Not super likely of course but a bummer for sure.
Watauga
Senior Member Joined: June-12-2009 Location: United States Status: Offline Points: 208 |
Lee,
I appreciate your hard work and long hours you invested in the old gal, you should be able to enjoy her many more days. Congratulations! A couple of questions. It looks like you partially removed the primary stringers, and did not disturb the airbox. If that is true, how did you join the remaining existing stringers with the new? It also appears that when you removed the primaries and secondairies that you left some of the existing stringer fiberglass lamination intact. Did you install the new primaries and secondaries against the remaining vertical fiberglass or did you actually remove it before bedding the new stringers to the hull? What was you process? If you left some of the old fiberglass how did you achieve adhesion? |
lharley
Newbie Joined: April-20-2017 Location: Lexington, SC Status: Offline Points: 33 |
Watauga, i am going to answer all your questions. Just haveing a busy week.
lharley
Watauga,
Here we go I will go through all your questions and hope I answer the best I can. I am sure that the "experts" on this site will find fault in or a better way to do it. I am not a boat mechaninc but I am very good at what I do. I am a carpenter a machinist and a decent mechanic. "It looks like you partially removed the primary stringers, and did not disturb the airbox. If that is true, how did you join the remaining existing stringers with the new?" I removed all the primary stringers up to the first bulkhead where they were solid after that. I joind them with biscuits, epoxy and fiberglassed the *************** out of them. "It also appears that when you removed the primaries and secondairies that you left some of the existing stringer fiberglass lamination intact. Did you install the new primaries and secondaries against the remaining vertical fiberglass or did you actually remove it before bedding the new stringers to the hull?" We used the existing stringer fiberglass to set the new stringers to get the right width, hight and just for stability when setting the new ones. We then used epoxy to set them in place and we cut the old material out and fiberglass out and replaced it with new fiberglass. We did not use any of the old fiberglass to bond to we just used it as a templet and a base set to work off of. As stated I am sure there are other ways to do it and I am sure you will hear about it. This was my way hope this works and please ask if you have any more questions. |
lharley
Just got the boat from the shop and have it at the house now. Got it running like a top and it is looking good. All I need to do is put the drivers chair in. We are taking it to the lake house next weekend for the summer. Can't wait to get pulled !!
lharley
The wake tower is a Big Air $550 off their web site. The top I made myself. I had some 1" steal tubing I bent it with my bender welded some bracing in it and made the front supports out of 1/2" tube. I put a 15 degree down slope in it. Painted it black ordered the Sunbrella fabric off Amazon along with the grommet kit. Had the wife sew it up and tied it into the frame with 550 cord. The whole thing cost me $200. It has saved many hours of not getting sun burned on the lake. It is the best thing I could have done to the boat if I am going to be pulling teenage kids all day. Love it best $200 I have eves spent.
lharley
Ok after lots of thinking and research I decided to take the advise of a few people and run my gas return line back into my carb insted of the vent line on the gase takn. I plugged the tee that I put on the vent line. I didnt want the line exposed and I didnt want to have to modify my K&N flame arrester fliter. So I got a 1/4" bulk head and drilled a 3/8" hole under the housing and ran it up that way. Still gives it that clean look and serves the purpose of running the gas line in to the carb. Lets hear what you think.
lharley
Got her back on the lake this weekend. She ran smooth only one tiny oil leak on one of the valve cover gaskets. The rubber gaskets I got from Summit Racing for $39 were leaking. I went to Auto Zone got 2 cork gaskest for $16 and it sealed it right up. Ran it all day Saturday and Sunday no Issues. Re-set the speedometers with my GPS they were only about 2 MPH off. It felt tight and ran great.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10637 |
Well since I was the one who originally brought it up I guess I can be the first one to say "Good job, I like it"
It keeps the fuel tank vent line configured the way it's supposed to be too. Glad you did some research about it. |
Lee
Nothing urgent but do you think sometime you could take a picture looking straight down at your distributor with the cap and rotor removed so the weights and springs are clearly visible? If you could add it to this thread or PM me, either would be fine Thanks |
lharley
Keno,
Here is the distributor I used. PerTronix Flame-Thrower Plug and Play Marine Distributors with Ignitor II® Module D231800 I just had to swap out the gears to the RR gear. |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1720 |
Good looking boat and clean work. Looks great.
Got it, For some reason I was thinking you had an Ignitor 3 setup that I'm not familiar with.. I'm familiar with what you have and like them a lot. Many trouble free years on those modules and that same distributor despite what some people on here think. Notice that I didn't even mention your name Pete, I just said "some people" |
DCIndustries
Groupie Joined: July-13-2012 Location: Orlando, Fl Status: Offline Points: 78 |
Nice Work! I've been fixing up my 87 for about 3 years now.
Working in a machine shop have you ever considered cutting the dash panels out of .090 aluminum? I had it cut on a cnc router to fit my stereo and converted rocker switches. Painted to match. Came out great. I can get you cad files to get ya started if your interested. |
JOE. R
Newbie Joined: April-23-2017 Location: Florida Status: Offline Points: 1 |
Nice job. I recently bought a 87 Ski also. Thanks for sharing.
n7narcosis
Groupie Joined: October-12-2016 Location: Delta,BC Canada Status: Offline Points: 41 |
@DCIndustries
1989 Correct Craft Martinique CB --- 351W
Blamey
Gold Member Joined: August-18-2015 Location: White Plains,NY Status: Offline Points: 631 |
Is that Drivers seat a complete rebuild or is that a transplant from somewhere else? I'd like to see more pics of your boat. I really like the look of the updated vinyl. EDIT: Never mind I found your boat project post. Nice work. Still interested in how you did that drivers seat. |
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme |
quinner
That drivers seat looks to be a factory seat being used in the current model year CC's
DCIndustries
It's the current G Series seat. I managed to scrape together parts here and there, cut and stitched vinyl to match the rest of the boat. Haven't been able finish the custom driver's throttle panel or rear subcoamings so I haven't updated my post yet.
lharley
Great way to end a weekend !
lharley
We ran her all weekend this past weekend and besides a little tuning on the carb and setting the tranny adjustment it ran great. She was shifting into gear a little soon causing a jerking. So I adjusted the throttle and tranny cables to allow it to shift into gear at 750 RPM and then there is just a tiny amount of slack before you give it throttle. It took maybe 30 min to get it right. Everything else seems solid.
Timr71
Groupie Joined: March-28-2016 Location: Alabama Status: Offline Points: 80 |
I had to make similar adjustment when I rebuilt my Morse 2 control connected with new throttle and shift cables.
The boat looks great! You should really enjoy it. |
angryginger
Newbie Joined: June-12-2019 Location: Orlando, FL Status: Offline Points: 1 |
Old thread but quick question if your still around.. did you leave it on the trailer for your stringer rebuild or take it off? If day what did you put it on how did you support it ?
sam nielsen
