swim platform bracket/transom angle |
Atmspltr
Senior Member Joined: May-04-2005 Location: United States Status: Offline Points: 170 |
Posted: July-06-2006 at 9:39pm |
Does anyone know the angle of the swim platform brackets for a 67 Mustang? Is it the same as a mid 70's Ski Tique?
captinr
Groupie Joined: February-01-2006 Location: United States Status: Offline Points: 45 |
Am doing the same project on my '68 Mustang. I used a dial angle gauge on the transom and came up with a 10 degree transom angle and 12 degrees on the swing angle for the brackets. Alloy Marine is sending the brackets this week. Will post the results. Thanks again to DrCC for the first rate swim platform.
69 Mustang
Senior Member Joined: April-26-2006 Location: United States Status: Offline Points: 402 |
How did this work out? On my 78 Ski Tique I calculated a 10 degree in-swing and a 10 degree rise angle. Now I'm concerned I'm off by 2 degrees on the swing...
Thanks |
"Where the **** are we?" Amelia Earhart. July 2, 1937 |
The Dude
Platinum Member Joined: October-19-2004 Location: Houston Status: Offline Points: 1334 |
i'll bet jim_in_houston knows. try emailing him.
Mullet Free since 93
95 Sport |
captinr
Everything worked great. I used 12 degrees on the swing angle to allow the brackets to mount in the centers of the rails on the swim deck. Your deck may be different. 10 degrees was perfect for the transom angle. I am installing a 3"x3" 10 degree angle bracket on the center of the transom this weekend to take the "bounce" out of the center of the swim deck. Alloy Marine sent me the bracket and I will report back with the results. Thanks one more time to DrCC for the custom swim deck
Atmspltr
I'm all done...8° transom angle and the outboard to inboard angle was a function of my platform. I determined the transom angle by leveling the trailer until the waterline stain on the boat was perfectly level. I then used a swing protractor and determined 8-9° past 90°. I made mine 98° and it was perfect in the water. I used 2.5" aluminum bar on the backside to distribute the load of the mounting bolts.
