New ARE shaft install and alignment |
SN2001_1984
Groupie Joined: August-13-2015 Location: Zeeland, MI Status: Offline Points: 56 |
Posted: April-26-2017 at 4:19pm |
Guys, working on my 83 SN....installing my 'new to me' ARE dual tapper shaft today and wanted your thoughts on the alignment in the log - I put new bushings in the strut and this is where the shaft sits in the log unsupported - a bit low but I assume because its got some weight to it. Think the strut is aligned to the log?
Also wondering......is the original style dampner plate? I assume I should change it.... Thanks for the advice! |
1984 Ski Nautique 2001 :: 351
Original factory ordered color combo from Silver Spray Sports: Fenton MI |
Dreaming
if your damper plate chatters, or has a lot of hours on it, it might be a good time to change it. If you don't mind pulling the trans again in a couple of months (or later if it's good), you can save a couple hundred $$ by running the one you have.
JoeinNY
Agree with all that except the couple hundred part - you can get a damper closer to a hundred. Unsupported that shaft alignment looks pretty good to me. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10645 |
This would most likely be the plate Joe speaks of
damper plate or if you want to save 20 bucks you can buy this one and trim it yourself untrimmed version It's gotten good reviews over the years on CCF. 3 bolts to hold it on instead of 6 is mentioned in the ad.and nobody has had a problem with using only 3. You could search for CCF threads on " damper plate" and see what comes up. |
The Sachs plate is excellent. Nice spring support top on bottom unlike the stamped pockets that do not have flat bottoms. Duane, would you ever dream of putting a square wire die spring in a hole bottom that isn't flat!! Ken, The shear of the 3 bolts even if they are grade 2 is way beyond the torque of even a big block. Not even a concern with me. |
Denny,
Take the weight off the forward end of the shaft and then make sure the shaft is "happy" (turns freely) in the cutlass. |
SN2001_1984
Duane/Joe/Ken - thanks for the advice ---- I just bought the dampner on ebasic power! I have no idea how old the other one is....boat has over 1000 hrs on her so i'm sure it needs it, plus an upgrade as Pete said!
Pete - I just checked the 'happiness' of the shaft in the strut/cutlass....its a little tight as shown in the pic and as soon as I take weight of the front it spins nice so I think I'm good to go! Thanks for the advice! Now to wrap up the velvet drive/wait for dampner plate and complete the install! You guys all rock! |
Denny, Yes, you're good to go! |
