  New Posts New Posts RSS Feed - Clicking sound when starting
SKIGT40 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SKIGT40 Quote  Post ReplyReply Direct Link To This Post Topic: Clicking sound when starting
    Posted: June-19-2017 at 8:00pm
Hi All
I did a compression test , when I did this , I pulled the two big relays fuel pump and ecm. Then un plugged all the ignition stuff. When I connected it all back up and went to turn the key I just got a big click sound. Then I tried again and it started right up. However now it dos this all the time when I go to start the boat it makes the click sound then I back off and try again and fires up no problem. What could this be?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SKIGT40 Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2017 at 8:04pm
Sorry it's a 95 ski nautique gt40 efi
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2017 at 8:29pm
Battery posts and battery cable terminals? What did you use to clean them and when was the last time? You hopefully don't have a deep cycle battery!
Joby1969 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joby1969 Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2017 at 8:39pm
   I was thinking a bad connection someplace as well.
my 1980 SN is mad at my 2009 HD
Post Options Post Options   Thanks (0) Thanks(0)   Quote SKIGT40 Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2017 at 8:41pm
Battery is a interstate that Larry from SN customer service recommended its only two years old the post clamps were new last year the whole tremanal area is very clean.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2017 at 8:49pm
Interstate starting, dual purpose or deep cycle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SKIGT40 Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2017 at 9:03pm
The model number is C65-XHD. I think it's just a regular battery for a v8 truck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2017 at 9:13pm
Russ,
Larry did well with his recommendation. Sometimes you never know about "customer service"
