1976 Ski Nautique Restoration Project |
Post Reply | Page <12 |
robdubbleu
Senior Member Joined: December-26-2016 Location: Mt. Island Lake Status: Offline Points: 120 |
Thanks for all the info, guys! Keep it coming!
I have already contacted Holley and determined that rebuild kit 703-29 is correct for my carb (List - 50463) I'm going to order the kit, as well as a solid metal fuel line. Then I just need to find somebody who knows what they're doing to rebuild it, or help me do it. |
Ken, I thought the rubber/rope came in 78 but I certainly could be wrong. My 77 has the old aluminum J. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10719 |
Looks like they also put on the rubber rub rail with a rope insert that didn't show up till after 76. At least mine didn't have one when it was new and I got the rubber one a few years later
Your carburetor pictures tell me a few things about your carburetor One is that the 4 bowl plugs, 2 on each bowl have been epoxied over, probably because they leaked at some point. Or at least the 2 top ones that are visible have been epoxied. In this link to an old thread you can see what the plugs look like. There's an O ring that goes bad and plenty of people have epoxied them with good results. It also looks like a later carburetor than what came on the 76 PCM's based on where the fuel pump overflow line taps into the carburetor and also the non externally adjustable float bowls that came along in later years. None of these are bad things by the way. Kinda tells me they did some maintenance and replaced some parts to keep it running good If you're looking for a rebuild kit for the carburetor, find the list number on the air horn to help you get the right kit. Here's a picture of where to find it [/QUOTE] |
That is not a commander conversion... it looks genuine pcm right down to the decal on the flame arrestor.
Gary, Waukesha became pcm and were available as early as '72. |
Rob,
The metal line from Skidim works although there may be some slight tweaking needed on the bends. |
robdubbleu
I see. I'll definitely order a solid line. The top of the flame arrestor cover says Pleasurecraft on it, so I'm guessing it's PCM...? I don't really know anything about the Commander conversion |
I was just guessing, I would have thought it was a Commander conversion back in those years. Commander was eventually bought up by PCM. Yes on that first metal line,thats what was on there originally,some where along the way someone cut some off and added the rubber hose.
robdubbleu
Thanks! What's on there now is a metal fuel line from the fuel pump which then connects to the rubber hose pictured above. I assume the first one in the list on skidim just replaces the whole thing with a metal fuel line? You said mine isn't a PCM... do you mean the fuel hose in question is not PCM? Because the engine is. Thanks! |
robdubbleu
Some of you helped me out in my thread about my 1974 SN where I was trying to get help with bringing the boat home (from my grandparents' place). Well turns out the boat is actually a '76. Thanks to some of you, I was able to purchase the correct hubs for the trailer, replace them, and put on new wheels and tires. Got it home with no problems. As I think I mentioned in my other thread, it's not running right now but I think the carburetor needs a cleaning or rebuild (and the olllld gas removed from it). Check it out...
One of the first things I would like to do while trying to get it running is replace this hose. Where's the best place to get it? |
