Removing screws from hull |
beebe
Newbie Joined: May-15-2017 Location: Arkansas Status: Offline Points: 32 |
Posted: July-31-2017 at 11:34pm |
I'm replacing my bilge pump in my 86 nautique. The old bilge pump is screwed in to the hull. I was thinking maybe remove the old screws and fill the holes somehow. Then epoxy in the new bilge pump base. Is this a good course of action? How should I fill the old screw holes? Should I use the same epoxy? I have some west systems epoxy and hardener on hand.
Or is there a better way to go about this? Thanks, Roger |
2001SAN
Senior Member Joined: June-26-2012 Location: Ireland Status: Offline Points: 241 |
I replaced my bilge pump with a different model and drilled new holes in the base so I could use the existing holes. I am glad I did because the new pump quit and I ended up putting the same model back in and was able to use the original holes again.
D. |
A little knowledge is a dangerous thing...
2001 Super Air Nautique 1989 Fairline Corniche 31 www.bannrivercruises.co.uk |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2822 |
I fill holes with 3M marine adhesive / sealant (4200 or 5200).
JQ |
beebe
Perfect... just ordered some.
I may reuse the screw holes, but I also need to remove a broken float switch. The new pump is a rule automatic one. |
