Help with low idle |
jblocal
Senior Member Joined: September-06-2010 Location: Stuart, Florida Status: Offline Points: 203 |
Posted: August-26-2017 at 9:07pm |
My idle is to low and I can't seem to bring it up without coming off idle circuit. When I turn the air fuel mixture screws all way in engine idles better and smoother. Checked for vac leaks can't find any. Checked timing and even tried advancing it a little. Cleaned the carb didn't solve problem. Figured had to be the carb so I installed a new holley with same results. Engine never dies but bothers me cause I hear the dampener knocking. Im not sure what else to check.
SNobsessed
How is your compression?
jblocal
I havnt checked that. I have a new longblock only couple years old. Never had any issues but I'll give it a look.
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2974 |
There's a problem if your idle mixture screws are all the way in and the engine is still running.
Intake manifold leak? Vacuum leak from somewhere... |
