Parts for sale Ski Tique |
tk421
Newbie Joined: August-30-2017 Location: WI Status: Offline Points: 2 |
Posted: August-30-2017 at 5:45pm |
Parting out 1978 Ski Tique- located by Lacrosse WI
The Guide fin is bent, the strut and driveshaft are bent. Has cracked block- but engine started and ran fine. We took a video of it running and shifting. Reverse rotation Chevy 305- see pics -nothing taken off yet.- composite oil pan Borg Warner Velvet Drive Trans 1-1, bellhousing and inline cooler- basically the whole thing $900 or offers. Still in boat and we have a video of it running and shifting. Will be removed the next few weeks- cheaper if you do it. starter $20 alternator $20 Thermostat housing and hoses $20 air cleaner $15 Rear fuel tank cover $30 manifolds and risers- one Chinese the other looks domestic $100 for all 4 items Electronic Dist $50 wiring harness $15 20 gallon fuel tank $25 Seat brackets $25 Dog House $80 Cold water Pump $45 Circulating Pump $45 Fuel pump$10 Rudder assembly $100 Windshield Offers- depends on if you take off or I do., glass all looks good. Throttle assembly- yet to be removed $50 Steering assembly $30 Ski Pylon $100 Mirror $45 Dash parts- all the gauges work; but they are kind of cruddy All the hardware- depends on what you want Prices are negotiable depending on what you buy and if I have it off already For pics and contact info https://lacrosse.craigslist.org/bpo/d/1978-ski-tique-parting-out/6284826551.html |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1722 |
Cold (raw) water pump? What type?
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 933 |
Carburetor? What brand/model?
1980snryan
Newbie Joined: September-03-2017 Location: Angola Status: Offline Points: 31 |
Will you ship the pylon?
butchie
Groupie Joined: September-23-2017 Location: baltimore, md Status: Offline Points: 46 |
Im restoreing 1975 sn, Im looking for both bow and stern lifting rings, Also ski pylon.If you have those,I really want to buy. Please let me know ASAP, Thank you. Butch Chew.#410-725-2944
chau8238
Groupie Joined: August-08-2017 Location: Houston Status: Offline Points: 75 |
Do you have the coupler that goes from the transmission to the prop shaft? My key is messed up and it looks like someone modified my coupler that slides onto the shaft so I'd like to find a good one to replace it with. I had my shaft come loose this past weekend and would like to avoid that in the future. Any pics of what you have?
Also, what style of throttle mechanism does it have? Mine has excessive play/slop and would like to replace it. Thanks. |
Phillip, The coupling to the prop shaft is a heat shrink interference fit. The coupling does NOT slide onto the shaft. Due to shafting diameter tolerances, it's common to bore the coupling to match the shaft creating the .000 to .- 0005 fit. It sounds like your boat has been run with misalignment fretting the shaft and coupling. You need a new shaft and coupling! Double taper ARE or General Propeller systems are the way to go since it eliminates the heating of the coupling to install it on the prop shaft. Regarding the slop in your helm control, have you checked your connectors? |
Duane in Indy
Why buy a new shaft when yours can be machined into a double taper??? About 1/2 the $$ for the same setup. I have converted numerous shafts. |
1978 Mustang (modified) |
Duane, I have a suspicion that Phillips shaft isn't in the greatest shape. Besides machining the taper, you'd probably end up straightening it too! |
chau8238
The shaft may not be the best, but I'd like to make it last through this season if possible. But someone modified my coupler to have 2 set bolts perpendicular to the keyway. I'll create a new thread so I don't hijack his.
The two set screws are only there as a back up for a fretted loose shaft and coupling. They are NOT for tightening the coupling to the shaft. The idea is they prevent the shaft and prop from sliding aft and hitting the rudder. |
tique79
Newbie Joined: April-15-2013 Location: United States Status: Offline Points: 15 |
Interested in complete assembly of windshield if you still have it. Are you able to ship this item?
Thanks Bill |
mn 75 sw
Newbie Joined: October-06-2017 Location: Minnesota Status: Offline Points: 7 |
I am interested in the ski pylon if you still have it. Please call or text me at 612-910-2040. Thanks!
Scott
612-910-2040 kohlsfive@aol.com |
Sam B
Senior Member Joined: November-17-2007 Location: StevensPoint WI Status: Offline Points: 393 |
If anyone knows how to get ahold of this guy I please let me know! I am in need of an engine cover for a project and he is only about an hour from me. Thanks!
JerryP
Newbie Joined: September-29-2017 Location: Kokomo, In Status: Offline Points: 4 |
Looking for lower left front windshield vent window. Jerry
Matt lutz
Newbie Joined: April-14-2018 Location: Hamburg,pa Status: Offline Points: 17 |
I want the rudder assembly ..please contact me
Owen_83SN
Newbie Joined: April-10-2018 Location: Alabama Status: Offline Points: 7 |
Can I buy your shifter from you ? I only need the arm, not the entire assembly. Please let me know. Thanks !
Swingmatt
Newbie Joined: November-02-2017 Location: Acworth Ga Status: Offline Points: 21 |
I’m interested in pylon, please call or message if still available.
Thanks Matt 6787774926 |
