  New Posts New Posts RSS Feed - Tow SN with Toyota 4Runner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Topic: Tow SN with Toyota 4Runner?
    Posted: November-25-2017 at 1:37pm
Looking at a new tow vehicle. Top of the list is the Toyota 4Runner. I've got a Ski Nautique Open Bow with 2 axle trailer. I estimate 3,800 pounds weight of boat / trailer combined.
I live in Utah, so mountain / high altitude towing is part of the experience. Anybody have 4Runner towing experience? I don't need to win any races, but I don't want to run 50 mph on the freeway either.
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 2:34pm
An old SR5 4 runner? 22RE? 120hp? no way pal.
Im sure the new ones are heavier with a v6 and better towing capacity. 4X4 always ups the rating as well. probably fine.
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 2:37pm
Should do what you're looking to do. It won't be a champion tow vehicle but it's certainly not too shabby. At least it's got full body-on-frame construction.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 3:17pm
If I recall 4wd lowers your tow rating because the vehicle weight is greater and deducts from the gross vehicle weight total. That said I would not tow boats without it. You don't want to be "that" guy at the ramp.
JD ski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD ski Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 3:42pm
The 4 Runner has a 5000 lb. tow rating and a gross vehicle weight of 6300 lb. So the answer is yes it will tow your boat without any issue. However, when the boat is loaded and the 4 Runner is loaded with people and gear, you will be near the limits. It does not appear that TRD is making superchargers although Magnuson probably is. A supercharger will not change the tow rating but will change how you tow in mountainous areas. I live across Nevada from you and tow with a Tundra equipped with a TRD sway bar, air bags and 35 in. tires. Power wise when climbing mountains I know my Air Nautique is behind me. With stock size tires you will be OK.
JD ski, slicing, dicing, and shredding since 1981
1999 Air Nautique, GT40 Pro Boss, Trail Rite trailer
1975 Century Resorter
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 3:58pm
Like this guy at the ramp?
We're going to need a bigger truck!!
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 4:43pm
I love reading these threads. The average inexperienced thinks they need an f450 duality diesel to tow an Atom Skier through Florida with no snow. A 4 runner will do just fine and my wife is after me to buy one as our weekend tow vehicle.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 5:42pm
Only real men tow Nautique's with Caddy's or Town Cars
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 5:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 7:55pm
Love the body-on-frame construction. Not a big fan of unibody construction for a tow vehicle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 8:01pm
Gary
You have that wrong
Only a real man would admit that he tows anything with a Forester
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 8:15pm
Is this what you were referring to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 8:44pm
Gary
You have that wrong
Like the lezmobile towing a ton of bricks?
79CC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79CC Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 9:56pm
a 4-runner should pull a Ski Nautique fine. I have an '03 4-runner 2wd with the v8 & air bag suspension, it pulls the ski tique easy. I mention the air bags because its handy, car will self level when you put a load in/on it,
Cheers
'79 Ski Tique
OldSchoolBlue84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolBlue84 Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 10:02pm
I have a 2016 4Runner limited and tows the 84SN2001 without an issue loaded up. Only negative is that the rear does sag more then I would like. Overall excellent vehicle and a blast to drive. Do wish it came in a v8 good luck shopping.
gt40KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gt40KS Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 10:12pm
JQ -- Throwing out the 4-bangers for consideration, the 4runner should have the horses and towing capacity easily enough, even in the mountains as long as you don't have a full load in both the vehicle and boat.   My only thought is the tongue weight capacity may be a bit low. You may possibly need some extra springs/ air bags depending on your actual tongue weight going down the road.   Also, the curb weight of the truck is only about a thousand #'s more than you're towing so it'd be helpful if your trailer had brakes to supplement the 4 wheel discs on the truck. And as mentioned before, 4x4 isn't a must .... but really, it is.   I've seen way too many 2WD's spinning their tires on wet and/or steep ramps.   Just my 2c
JCCI
1995 Ski Nautique GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 10:17pm
Gary
You have that wrong
YEP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2017 at 10:51pm
No more like this- V8,full frame,air suspension. Just a F 150 with a different body. I'd still have it too but no cooled seats
It could pull almost anything-
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2017 at 4:53am
When you pull in altitude and in steep terrain your vehicle really gets tested.
In flat ground not nearly as much. Even a V6 4 runner is going to have trouble going over a 8,000 foot pass towing near the limit.
I have towed my 78 Nautique with no trailer brakes with a 1984 Chevrolet Celebrity.   4 cylinder 3 speed automatic on 180 mile trips to ski lakes. The car was rated for about 2,000 pounds the boat and trailer was around 3,400 loaded. We were young and broke so we did this for a couple years. Flat ground up and down the CA Valley.
One time tried to take it to a lake about 2,000 ft elevation above our home with that car.
Being as careful as we knew how with that underpowered under braked car we smoked the brakes brakes. on a not to large of hill.   Stayed with flat ground travel after that till buying a better tow vehicle.
Since have towed with a 3/4 ton Suburban, I rate it number one for towing, transporting people and being able to lock up gear when you stop on the road for dinner or such.
Very stable and very safe, so much so you forget a trailer is behind you.
Towed with a short bed 1/2 ton lifted truck with huge tires and a big block engine. Plenty of power, the brakes were fine but the short bed does not give the feeling of stability of the longer bed tow vehicles do and you always feel the trailer back there.
Towed with a 2006 GM Trail Blazer with the 4.2 6 cylinder that offers 290 Horse Power and it did the job amazingly well surprisingly even in the mountains it pulled and braked well and never overheated but you know you need to be careful as the boat is closer to the same weight as the tow vehicle and you always are feeling the trailer behind you.
Steep hills in this rig were climbed in one gear lower and turning 4,000 RPM while the V8 cars would be 3,000 or less RPM. But this was only while climbing.
Next had a 1/2 Ton Suburban 4x4, It offered nearly everything the 3/4 ton did and rode much better when not trailering but it was softer and not as good towing as the same truck with 3/4 ton. It was still very good but you noticed it was not the 3/4 ton when towing.
Since have used a Yukon Denali the short wheel base like a Tahoe with the 6.0L and full time 4wd but it had the active suspension in it. This truck was actually amazingly good in all tow conditions but lacked the Low Range 4wd which I have to use frequently to get into a tight area we use.   It did the job but strained while cars with low range can almost idle it in with no strain. On the road though it was excellent, in town or high speed on the highway the active suspension really made it stable.
GM Tahoe 5.3L tows very well but never as good as the longer wheel base Suburban or the active suspension the Denali had, although it has the same power it is not quite as stable at 70 MPH on the freeway although it is really good for towing.
We also own a BMW X5 with the V8 option, 350 Horse Power and it tows well and is able to turn and maneuver the trailer very well but still does not offer the Low Range 4wd to help in our tight areas that most owners may never need to handle.   The BMW has much shorter wheel base so it tends to move around more than the Tahoe while towing but its brakes are superb and the power is very good for towing and it always feels safe but you know you are towing and do not forget a trailer is behind you..
I don't own and have not towed with a long bed 3/4 ton truck but I would guarantee they tow even better than the vehicles I mentioned and would hold up better in the altitude and mountain passes you will be working in. They can work much harder without stressing the vehicle. If you work a vehicle near max capacity frequently things fail.
Altitude kills power so a little extra is a great idea if towing in high altitude knowing you need to climb steep grades. It is no fun climbing hills at 20 MPH while traffic blows by at 60 MPH. Yeah, I have done that when I was young and too broke to upgrade my tow vehicle.
Smithfamily View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smithfamily Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2017 at 9:41am
I, too am looking at the 4runner! I am impressed with the value for the $ ($40k +/-) and the great reviews it shows from long time owners. V6 is 270 hp, As stated we do not have issues with the altitude in Florida, but I can recall a few situations where a steep ramp posed a challenge, when towing with an F150.
I agree with MrMcD that the Suburban is the best, and our current tow vehicle, but it is ugly and aging and time to replace. New Suburbans are the cost of a small home, and the used ones are outrageous$ with over 100.000 miles.
Js
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2017 at 9:54am
Mark,curious on the final drive ratio on the Tahoe with the 5.3 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2017 at 1:04pm
I'm assuming from his comments it's a 6 speed with 3.42, but he'll have to confirm. My Tahoe towed very well, but with 5.3 you have to be willing to wind it up into it's powerband, people who like towing without downshifting tend to say the 5.3 doesn't tow well, which to me is not true. Having said all that my Durango with 5.7 and 8 speed tows MUCH better than the Tahoe, no comparison.
To the OP, consider a Durango. There are nice models in your price range and the 3.6 V6 tows well and is a nice all around package. I like the 5.7 V8 a lot but no question the V6 would tow a 4,000 lb. boat and trailer quite well even in the mountains.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2017 at 5:28pm
I have owned 3 of the Tahoe 2000 to 2006 bodies so they all had 4 speed auto trannys.
Our 2002 Tahoe 5.3L had 4.10 gears, the Denali with the 6L had 3.42 gears, Our Yukon with a 5.3L I still have has the 3.73 gears.   For towing the 4.10 gears helped.
Both our Suburbans had 3.73 gears, I think the Trailblazer ran 3.73 but can't say for sure..
I think the 3.73 gears offer the best all around but for me we have Lake Tahoe Mountains just east of me so pulling steep grades is important.
Funny thing to me is all three of the TAHOE bodies with 2 different engines and 3 different rear axles got almost identical mileage.
The X5 has 6 gears and keeps it able to pull hard at any speed.
The Durango with a Hemi is formidable, with 8 gears I can see them being very good to tow with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2017 at 7:22pm
TRBenj does a lot of towing with a 4Runner - his input should be solicited
Tim_2001PNW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim_2001PNW Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2017 at 9:04pm
I have 2016 4Runner and pull an 84 Ski Nautique, from what I can tell it does a great job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2017 at 9:51pm
4Runner? Suburban? Tahoe? Durango? None are good at towing. I've got a new Ford ordered!.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2017 at 9:57pm
What's that say on the side of the truck? Velocraptor or maybe I missed an I in there
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: November-26-2017 at 11:29pm
While I like the concept of the Raptor, and a friend of mine has a tuned one that is pretty impressive, at the same time the idea of a big tough pickup that can't have a plow mounted on it bothers me a bit.
Mark, I don't know if its the 8 speed on the Durango or the torque delivery of the hemi, but it's impressive. No tow mode, the shift pattern adapts to load and seems to know when to downshift so very little pedal input is needed to hold speed.
geecee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geecee Quote  Post ReplyReply Direct Link To This Post Posted: November-27-2017 at 4:59am
This statement rings true.
I actually laugh at the vehicles you guys in the States use as tow vehicles, yes I am jealous but goodness, talk about overkill.
I tow my waterlogged and fully loaded '83 with camp gear in the car and humans with previously a 2.2 diesel Ford Ranger, and will now be with a 2.4 Diesel Hilux. It works, I don't win races, but the tow capacity is fine. My closest body of water is around 20 miles away and involves some steep inclines and declines to get to and I manage just fine.
PS: my trailer brakes are not connect currently and I have still had no issues. (yes its illegal, its a new axle and I need to get the lines run)
And yes generally 4x4 has a higher tow rating, The 4runner is a much better specced vehicle :)
1983 Ski Nautique '2001'
-Chev 350 Mercruiser
-Custom Wake Tower
-Custom Interior
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: November-27-2017 at 9:56am
Graeme, I still have a 2006 Jeep Liberty CRD with the 2.5 diesel. It has a tow rating of 5,000 lbs. and has towed my Sport very well. You are right, we all feel like we need a huge amount of power so that we don't ever drop 5 mph during a trip!
