  New Posts New Posts RSS Feed - 1990 BFN
1990 BFN
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Topic: 1990 BFN
    Posted: December-22-2017 at 2:41pm
Hey Fellas, just getting time to post our latest ride. This fall a local guy (knew him from my N3 Days and the river) had for sale a brochure color scheme 90 BFN.
The boat has been maintained mechanically pretty well other than a junk Dizzy and dirty neutral. Structurally and interior wise it's in great shape just needing the observers seat base and drivers seat base replaced.
Winter plans include a transmission rebuild/trailer refurb for function/wet sand buff and decals.
I will update this thread as we make progress but here are some photos from when we picked it up. Sorry they aren't the best.
The motor runs exceptionally well despite having a locked distributor timing mechanism. It went 50.0 on GPS with the tach showing around 4950.00 running Tim's spare 430. GPS confirmed speed by a Garmin Etrex not an I phone app. Mid range and hole shot are so good I would be reluctant to step up to a 1598 for an extra mph up top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 2:51pm
Hello Fella.
Nice guide pole.
How many phone books to drive?
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 2:59pm
3 and one extra I ripped in half.
jimsport93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimsport93 Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 3:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 4:36pm
Very nice boat Zach! Great colors. Looks to be in really nice condition.
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 4:40pm
Gotta love a BFN - well done Zach!
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 5:32pm
Have you done a transmission yet??   If needed I can assist. ( I only do a partial rebuild cause I don't know what a full one is yet, still waiting )    Duane
        1978 Mustang (modified)
illiniball2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 5:52pm
Cool! i personally dig the color scheme as well.
Beer is my friend
87 Dominique
Had 67 Starflite
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 6:20pm
Ah.......................A trip down memory lane Duane
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 6:22pm
Sha-weeet. I want one...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 6:30pm
Duane,
I thought we covered it but maybe you missed it. I sure miss things a lot probably due to my ADD!!! Beyond clutch packs, bearings and seals, the only other thing I feel is needed is checking the health of the pump. There are specs on pressure but the trans needs to be assembled and turning to use that. I know Eric used to chuck his rebuilds up in his lathe to check. The only other way is to check pump clearances and I have yet to find Velvet specs on them. I do know with a geared hydraulic pump .0005 at the teeth and the same between the gears and housing is a rule of thumb.
Zach,
Nice!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 6:33pm
Sweet boat Zach. Will look forward to updates and a ride in 2018!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 7:23pm
I hook mine to an old riding mower with a horizontal shaft and an electric clutch.
A splined hub from an old damper plate welded to a pulley and a v belt make things go round.
Depending on where I mount the transmission, I can do righty's and lefty's.
Due to the "hackish" nature of this setup I usually do it in the backyard under a shadetree at night
But.................it works
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 7:42pm
Ken - Do you get the pulley lined up within .003?
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 8:02pm
I am looking forward to seeing that boat up here on Deep Lake sometime. Ought to be looking like brand new with your experience and connections!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 8:27pm
Probably within 3 inches anyways. Pete would be proud of my alignment job
Rubber belt with a little twist of sorts, it's a good thing I don't have to run it very long to check pressures. Transmission angle is a little funny too, to get things lined up pretty close.
I keep saying I'm going to build a better bracket but I don't use it very often
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 9:04pm
Chris,
Here's Ken's guide to his 3" alignment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 9:21pm
I think every one of my boats has some degree of parallel misalignment. I'm a failure, but at least I carry a spare belt with me!
Ken, that setup you describe is awesome!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 9:23pm
And more importantly, congrats Zach!
The frozen timing in the distributor - how it is running that strong without a decent amount of advance? Surprises me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 9:46pm
David,
The way Zach worded the timing problem threw me too. After reading it a couple times, I have a feeling the distributor is frozen in the block rather than the advance mechanism being frozen???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 9:55pm
I don't think it's frozen in the block "locked distributor timing mechanism" I think it's either stuck in full advance or it's stuck in the opposite
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 9:56pm
Nope, I'd say it's the advance that's frozen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 9:58pm
Or maybe Zach sits in a jump seat with the motor box off and manually rotates the distributor to get max speed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 10:31pm
Chris,
It's a combination of all 3 of those pictures
And the pulleys are fairly ugly and rusty too
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 10:34pm
Nice Find. I love the color scheme. Does also seem to be in great shape.
Donald
1968 Ski Nautique, Project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2017 at 11:34pm
Well done
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2017 at 1:22am
"pics or it didn't happen"
john
Smithfamily View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smithfamily Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2017 at 9:10am
Haha!
john
Js
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2017 at 11:17am
Beyond clutch packs, bearings and seals, the only other thing I feel is needed is checking the health of the pump. . The only other way is to check pump clearances and I have yet to find Velvet specs on them.
Spec sheet would be nice but like you, I have not been able to come up with any.
Future thought:   If Zach decides to install a new pump we would be able to check new dim's against used pump dim's. Pumps are really not that expensive. I did do a visual on my pump components and could see no wear marks on gears or housing. ( FWIW).
It would be nice to set up a pressure test fixture to check the relief valve also.
Frankenotter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2017 at 12:22pm
She's a beauty Clark.
I want one.
1999 Ski Nautique 196
