Bad gas? |
Post Reply | Page <12 |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10606 |
Your favorite brand of course |
jblocal
Senior Member Joined: September-06-2010 Location: Stuart, Florida Status: Offline Points: 203 |
Got it all put back together with the gt40p heads and new exhaust, Started right up and sounds great in the driveway. Hopefully going put it in the water tomorrow after work. I’ll report back with results.
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3582 |
It will have more horsepower and torque with your new heads. A good move on your part.
Glad you got it back running again. Since you now have more compression you will want to verify how much timing you have at 3,000 to 4,000 RPM. You need to know the amount at this RPM so you know the engine is safe to run hard. Each head design has unique known timing constraints, some can only accept 28 degrees while others need 40 degrees for max performance. The 351W heads I believe are happy at 35-36 degrees but I will let others with more Ford knowledge advise you. A set back or dial back timing light helps to determine how much centrifugal advance your distributor has and if it advances smoothly without sticking. Once you know your advance you can set your timing at idle to allow the right amount at 3,000. Most want your centrifugal advance fully in by 3,000 for best performance. If you find your distributor allows 24 degrees of advance and you want 36 total timing at 3,000 you would set idle to 12 and your good to go. It is just math. If the distributor does not advance properly this is the right time to fix it. Proper timing makes a huge difference in performance and economy. Hope this helps. |
jblocal
Great! Thanks! Going have to look into that. Boat ran great today on the water. Throttle was lot more responsive even at higher rpm. I only brought it up to 3500 for a second. Cruised around at 3150 for while and was doing 26knot which feels a little faster. The exhaust even sounds better. Going to check my timing and open her up next time.
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1796 |
How are you determining when detonation occurs? Are you going by ear? Dangerous territory! Are you using 87 octane as your base fuel? |
If working on a boat I always assume 87octane. Many times it is all you can find on the water.
I like to stay conservative on timing since I have seen many detonation damaged engines in my career . Adding an extra 2 degrees timing can offer a couple more horsepower but in my book it's not worth the risk. You are correct that serious detonation can be silent. You just feel the engine start to lay down on power. I have seen fractured rings, broken pistons, blown head gaskets and pounded out rod bearings from detonation. Most of those guys say the engine was running the best it ever had right before they blew up. I would stay with a known safe total advance number for a 351w with the P heads and with a carburetor. As stated I think he would be OK at 35 or 36 but I don't know so I'll let the Ford experts advise. If it pings at lower RPMs the timing curve is a little fast and it can be slowed down. |
jblocal
I had to put a timing tape on my harmonic balancer and Mark new lines last time I set timing. Marks are gone now I need to remark it. I didn’t hear any pinging running. Going to check it after work today.
tryathlete
We don’t need vacuum advanc e discussed in the attached link, because our engines are always loaded by the prop (there’s no light load at higher rpm to take advantage of vacuum advance). I really liked this link on the subject of ignition timing.
Importance of ignition timing |
I did a little forum searching and it is stated that the GT40P Heads have the fast burn chambers so max total timing recommended with a good fuel mix is 32. The GM 1996 and newer Vortec heads are similar in needing less timing than the older head designs for max performance. As hard as boat engines work you might want to start with 30 total timing and tune from there to avoid any detonation issues. Sorry to mislead stating 35 or 36 should be safe. With the old heads that would have been safe but not with the GT40P heads. I run a 1995 GT40 with P heads but it is computer controlled so I have not needed to check timing but thanks to your engine now I know.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21104 |
Gt40 has gt40 heads... not gt40p (unless you swapped them).
Thanks Tim. I know Chevy's, My Nautique has the Ford. Still learning.
jblocal
I still havnt got everything 100%. Can’t get my idle circuit to function properly. Idle screws all the way in makes engine idle better. Can’t find any vac leaks. Don’t see any fuel dripping. Pulled the carb cleaned it and checked powervalve. Vac is 14 at idle and compression was 120 on one side 118-119 other. 10 degree initial turning. Thinking either i need rebuild my carb which is pretty new or redo my valve adjustment. Especially after reading recent post on here. Can you tell from those numbers if valve isn’t adjust properly? And if they could have anything to do with idle circuit? Engine starts, runs fine, no noise, even idles damn good but rich.
I'm not a carb guru but if your throttle plates don't close far enough it causes the idle circuit problems.
If you can close the throttle more the idle circuit may start functioning better. When they are not closed properly the carb will pull fuel ignoring the idle circuit. If memory serves me correctly the screws on the side of the Holley adjust fuel flow. Screwing them in is supposed to reduce fuel. Look down the primary / front barrels a slot should be exposed with the throttle closed. Open the throttle all the way and look with a flashlight to see the full slot. Do a little reading and you will get dialed in how to set up your throttle plate setting. |
Is that 14 in vacuum at idle in neutral or idling in gear Here are some representative numbers from a post last year Had 20 in idling in neutral at about 700 rpm
jblocal
This is just idle on the trailer. I might be mistaking but I’m pretty sure I gave it some gas and vac actually increased to 20. I ordered some shims and Holley rebuild kit. Going go back thru valve adjustment one more time. Read great post yesterday on here gave me better idea. Think I’m also going drain tank and start fresh with rec 90. I’m about wore out working on it. Seems I’m stuck and going over things multiple times.
In neutral/no load vacuum will increase above idle. When you add load is when vacuum goes away or falls off.
The higher the load the less vacuum you have when in gear accelerating. As Keno showed with partial throttle opening your vacuum will vary depending on RPM. In a boat engine is always under load if in gear unlike a passenger car. In a boat at 30 MPH your throttle plates are probably 30% open so you still create a little vacuum, floor it and vacuum will be zero. |
14 inches is kinda low and 120 is too with the 40P heads unless your gauge(s) are off.
You've probably read about different causes which is probably why you're buying shims. You're probably referring to the link I posted the other day with Shep 72's method, it can't hurt to check. It works good. I'd guess you won't need the shims and that the valves are OK, but you'll know soon. |
jblocal
Update: I ended up needing to shim most of the rockers. Drained tank, rebuilt carb, and fresh plugs. 1 screw is responding now on idle/air mix. Other doesn’t seem to do much. Got the vac at 16 nice and smooth. Took the boat out today and performance wise has done better than ever. The gt40p head seems to have more power and huge improvement over the stock heads.
So how's your compression after the shimming?
Good news, sounds like you got it finally.
